Diesel Fuel Prices - What is everyone doing? - TheDieselGarage.com
Thread Details Posted by Gearloose1, this thread has received 20 replies and been viewed 3328 times.
post #1 of 21 (permalink) Old 04-14-2011, 06:23 PM Thread Starter
Gearloose1's Avatar
Diesel Fuel in most parts of the USA is now about $4 a gallon.
http://www.pilottravelcenters.com/Lo...Template=false
Or, a slight premium over the price of gasoline at around $3.70 a gallon.
What is it doing to our community?
Did you change your driving / usage?
Will you be considering a trade to something smaller? A gasser?
What about alternative fuels? Propane? Bio?
I cut back sharply on the number of miles driven --- and it is still a pretty big bite out of the wallet.
Gearloose1 is offline
post #2 of 21 (permalink) Old 04-14-2011, 07:12 PM
Old Fart
dbennett48's Avatar
I already have an economic Toyota Corolla for my daily driver. I do not use my truck as much as in the past. Fuel is $4.35+ here and gas is $4.09+. I am getting ready to take a trip to San Diego next week, by car.
Dave
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
post #3 of 21 (permalink) Old 04-14-2011, 08:39 PM
bootcamp's Avatar
I spent almost 600$ in diesel this time home. Now that summer is here I will break out the bike. A 220 mile trip to work cost me 23$ instead 75$. Thats 40mpg vs 15mpg.
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #4 of 21 (permalink) Old 04-14-2011, 09:17 PM
Stuck in Commiefornia...
IdahoF350's Avatar
Here in the desert north or Los Angeles, diesel is running $4.399-$4.899, 87 octane is $4.059+. It's hurting my personal finances, and killed off my business. Since fuel went back over $3.00/gallon I've watched my business disappear for the second time in 5 years. My income relies upon people having a little extra money and wanting to play with their toys. The majority of my customers had a couple hundred dollars a month cushion, but that is gone with fuel as high as it is.
I've decided that if I can't beat them, I'm gonna join them. I'm looking for work in the petroleum industry as I write this.
2000 Excursion XLT 4x4
IdahoF350 is offline
post #5 of 21 (permalink) Old 04-14-2011, 10:28 PM Thread Starter
Gearloose1's Avatar
Ford Motor Co. will idle a heavy-duty truck assembly plant next week amid softening consumer demand for full-size pickup trucks and a move by the company to conserve components following the March 11 earthquake in Japan.
The auto maker's Kentucky Truck Plant, located in Louisville, Ky., will close for five days starting Monday, Ford sales analyst George Pipas said. The plant produces such vehicles as the F-250 Super Duty pickup truck, Lincoln Navigator and Ford Expedition. The plant operates two shifts and employs a total of more than 4,000 workers.
In addition to the Kentucky plant, Ford said it is also idling its Flat Rock, Mich., plant for one week starting Monday. That shutdown is in response to building Mustang inventories. The auto maker had more than 116-days worth of supply at the end of March, far above the 60- to 80-day supply it traditionally keeps.
http://online.wsj.com/article/SB1000...142663176.html
Wonder if Ford 6.7 inventories are building ?
post #6 of 21 (permalink) Old 04-15-2011, 12:14 AM
Its about $4 per gallon at the end of my street. If I look around I can find it cheaper. The price of fuel is steep, but the truck is my primary transportation. I do what I got to do! Fortunately, I can take public transportation to work. I am planning a trip to Ohio, Arkansas and then Florida. I am going to have to plan carefully and figure out what it might cost me. Normally it would be no big deal. Just hoping the price of fuel holds for awhile.
2004 6.0L F350 Lariat Auto 4x4 CC/LB/DRW - sold
Sumimoto 255/70/22.5 on American Force Classic 22.5 wheels, 4.88 w/Truetrac rear, Mag-Hytec front/rear covers, Mag-Hytec 5R110W trans pan and '08 improved filter, custom front/rear springs from National Spring, Bilstein shocks, Bilstein dual stabilizer shocks, 4" stainless turbo back to a FTE single 6" stack, ARB Snorkel intake, Dfuser coolant filter kit, CFM++ Large Mouth, Doug's custom intake manifold, Powermax turbo w/batmowheel, Warren 175/75 injectors, ARP studded, custom CCV reroute, fan shroud removed, Diehard Platinum PM-1 batteries relocated, permanently installed battery tender with front/rear plug in access, HD250 amp alternator w/remote rectifiers, (9) ISSPRO Performax gauges, Nathan K5s, Warn hidden winch bumper kit, Warn 16.5k winch, Reflexxion steel hood, Jimmijammers, Britebox, Retro Solutions, ATTA 50gal Bed tank/tool box combo, Titan 67gal main tank..Hellman sumped, custom regulated return w/Fuelab pump, 6.4 oil filter canister, AMP steps, F650 lower dash w/nine switch panel , Carling switches, SCT X2 and stuff
boobin is offline
post #7 of 21 (permalink) Old 04-15-2011, 12:30 AM
Neighborhood toolbox :)
If the don't drop the price, then F them, they can keep there overpriced truck.
I don't want to have to put water and cat piss in my exhaust system anyway.
2004 Ford F350 4 door. 6.0 145000K, 6 speed ZF, NP 261 f 4x4 t case. Dana 80 4.10 rear, Dana 60 front. Wilco steel flat bed rigged to tow anything short of a big truck trailer. NO mods other than gauges and only ever had the ecm reflashed as far as I know. Oh ya and its red
Things that broke so far
29 Nov 2009: Turbo Charger Clamp
02 Aug 2010: Emergency Break pedal tensioner clip.
08 Feb 2011: Alternator died at 145,000 miles
Plufis is offline
post #8 of 21 (permalink) Old 04-15-2011, 12:41 AM Thread Starter
Gearloose1's Avatar
From the deepest bowels of gossip mills I track, incentives are within 30 days of coming out on full sized trucks.
The order book is holding in March because of fleet orders, but the view looking out is not good.
Oh, you have an alternative to cat pee.... just buy a few cases of 24s.
Small hole, make sure you don't miss.
post #9 of 21 (permalink) Old 04-15-2011, 12:41 AM
dzljon's Avatar
i drive my altima everyday and have done since 05, i use my truck for truck duties and for my creative outlet and plan on keeping it for along time i have already owned it for 10 years and i plan on 10 more my cummins is doing pretty good on fuel, about 70 miles to a 1/8 of a tank, i saw this coming as the economy recovers it was a matter of time till we got back to 06/07 fuel prices... i dont feel bad for those that just spent huge money on a 2011 diesel ,this summer when fuel hits even higher the dealers will be giving huge incentives to buy just like in 08...
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #10 of 21 (permalink) Old 04-15-2011, 12:45 AM
fine69's Avatar
I'm not doing anything different! Fuel prices are what they are and there ain't a damn thing we can do about it! If you bought an 8000lb truck as a daily driver and then can't afford it, well then you need to take a good hard look and decide if you really need that truck or just want it to be cool and "blow smoke!" These types of threads are really pointless!
H-M.W.H. Club #2
Union Club #1
Singles #237
B.O.M.B. Squad #12
Ridin' Dirty Club #17
American Club #15
fine69 is offline
The Following 4 Users Say Thank You to fine69 For this addition to TDG:
DEERE3594 (04-21-2011), joey83854 (04-26-2011), Rcannon (04-15-2011), S-D Diesel Perf (04-21-2011)
Human Verification
diesel prices? stroker_baldy The Parking Lot 51 05-08-2007 01:32 AM
Diesel prices? rocweiller The Parking Lot 12 12-06-2006 01:18 PM
Diesel fuel prices are high because.... diesel_ram_man The Parking Lot 9 06-25-2006 09:23 PM
WTF is up with Diesel Prices ???? frequentflyer The Parking Lot 51 10-27-2005 06:45 PM
GA fuel prices DavidTD The Parking Lot 6 10-07-2005 06:04 PM
