P7100 pump on a VE cummins - TheDieselGarage.com
Thread Details Posted by XXXcumminsXXX, this thread has received 16 replies and been viewed 12162 times.
post #1 of 17 (permalink) Old 03-21-2008, 07:57 AM Thread Starter
i was reading my diesel world magazine when i came across an article on swapping for a P7100 injection pump rated for up to 500 horse. does anyone know about this swap? how hard is it and how much does it roughly cost? would this be a good investment or no? any info is much appreciated. thanks again. cheers,
nick
XXXcumminsXXX is offline
post #2 of 17 (permalink) Old 03-21-2008, 08:14 AM
Send a message via AIM to jd_craft
i have heard about it alot the pump aint gonna be cheap i will tell u that then ur are gonna need the lines inectors plus the gear for the pump ull have to take the whole front cover off and time the pump to the motor the pump they are talkin about should be about 400cc pump this stuff aint meant for ultra low sulfer diesel either need to upgrade the turbo too and is ur truck intercooled it is a great investment especially if u want performance
jd_craft is offline
post #3 of 17 (permalink) Old 03-21-2008, 03:12 PM
The VE timing cover is different from a P-pump cover add that to the list.
Unless you can find the parts real cheap. Most of the time the cost of parts will be higher than buying a complete P-pump engine.
Philip is offline
post #4 of 17 (permalink) Old 03-21-2008, 04:17 PM
T.D.G. Mafia Member #88
cumminspride's Avatar
For 500 HP I think it's a waste of money. A 14mm H&R for your rotary and some turbo you'd hit that.
cumminspride is offline
post #5 of 17 (permalink) Old 03-21-2008, 08:23 PM Thread Starter
Whats an H&R? also my truck is intercooled. Sorry im a little new to the whole first gen thing...but i LOVE my truck. Its a '93 W350 DRW. Thanks again,
Nick
post #6 of 17 (permalink) Old 03-21-2008, 08:37 PM
what is sayin to is build up the ve pump its an ok idea probably cheaper and it would work if u only want to go to about 500hp but if u want to go beyond that i would do the coversion i not for sure but i believe u can use the kit for the 24v conversion to a p-pump all but the lines
jd_craft is offline
post #7 of 17 (permalink) Old 03-21-2008, 09:55 PM
what h&r stands for is head and rotor i found a place out in northern cali that has the 14mm head and rotor kit
http://www.rocken-tech.com/index.html give them a call see how much performance u will gain u would be different if u stayed with a ve pump i think 500 hp can be done with a turbo and built pump anyting over 500hp u need to do the conversion
jd_craft is offline
post #8 of 17 (permalink) Old 03-21-2008, 10:38 PM
01duramax6spd's Avatar
I'm planning to do the swap but haven't taken time yet. I got a complete P-Pump'd truck that had a locked up motor so I have everything. That'd be the best way I think.
01duramax6spd is offline
post #9 of 17 (permalink) Old 03-21-2008, 11:02 PM
the ve pump can make good power numbers 2 it is unquie to to see a ve pump make great power but a p-pump is the best out there
jd_craft is offline
post #10 of 17 (permalink) Old 03-22-2008, 04:29 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
You would be better off buying the 14mm pump head. You might as well buy another engine instead of swapping your ve pump over to a p-pump. You will have to replace your pistons, your head due to the ve pump injectors being different at the threads and the head casting holes are different as well. You will have to replace the front cover, front gear housing, the injectors, lines, intake plate, upper intake, the parts list will add up real quick.
Putco light bar
Dieselwrencher is offline
Human Verification
