Michael, great writeup. 2 questions though: 1: If the LP never delivers 14psi, wouldn't one run the risk of overheating the IP? I realize the ECM will throw a code if this happens, but I'm wondering why it doesn't happen more then? 2:Where do you get the banjo bolt with test port in it? I tried the dealer with no luck. Thanx for the help. Russ
Because there is a second return from the fuel rail at the back of the head.. This provides most of the return flow. The overflow is to keep the pressure from getting to high.
OK, that makes sense. Thanx Mike for all the info!! Russ
Related Threads
The Diesel Garage
1.2M posts
57.2K members
Since 2005
