P1689 ERROR CODE - Cause of code Found! - TheDieselGarage.com
Thread Details Posted by Mopar1973Man, this thread has received 6 replies and been viewed 17678 times.
post #1 of 7 (permalink) Old 01-28-2009, 07:19 PM Thread Starter
2nd Gen Guru
Mopar1973Man's Avatar
Well gang...
Mopar1973Man is back out in his shop and found the cause of P1689 error codes.
P1689 - No Communication Between ECM and Injection Pump Module Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.
A lot of us assume its the injection pump that causes this which in most cases could be. But I was doing a fuel pressure test (cranking). This requires to pull the fuel system relay out of the PDC box under the hood...
Lower left side labeled fuel pump...
When this relay is missing the VP44 doesn't energize nor pump fuel. It allows you to do the cranking test. But it also sets a P1689 and CEL light. So for all of you that have a P1689 error code present check your fuel pump relay first by trading with another relay!
Mopar1973Man is offline
post #2 of 7 (permalink) Old 01-31-2009, 02:03 PM Thread Starter
2nd Gen Guru
Addon to this post I did a short video of the fuel pressure test that causes the code...
post #3 of 7 (permalink) Old 02-01-2009, 12:47 PM Thread Starter
2nd Gen Guru
That's odd 52 people look at the thread and no comment...
post #4 of 7 (permalink) Old 02-01-2009, 01:42 PM
Heavy Equip. Is My Life
I am in awe... still trying to process! So you weren't trying to diagnose the 1689 by doing the pressure test, the code set after/because of the test, correct? It's amazing the amount of good info you collect/generate and post. I NEVER leave here without learning something. Once again, good job!
Russ
Late '99 F-350 7.3l 6sp 2wd Aftermarket dually kit 186,000mi STOCK
'99 Dodge 3500 24v 47re QCLB 4x4 DRW 131,000mi Straight-piped
'97 Chev 3500 6.5TD Auto-OD ECLB 4x4 DRW 199,000mi 4" exh. turbo to bumper
Deeslfxr is offline
post #5 of 7 (permalink) Old 02-01-2009, 06:08 PM Thread Starter
2nd Gen Guru
I can't seem to find the proceedure but it request that you pull the fuel pump relay from the PDC to do the cranking fuel pressure test.
When I was completeled the code was tripped... So it was a learning curve for me...
post #6 of 7 (permalink) Old 02-02-2009, 04:44 AM
i didn't look it up, but i believe thats what my truck threw when the suspect was the Throttle Positions Sensor (APPS) the truck would just cut out but stay running at an idle..... i'm not 100% sure....
are there any symptoms beside just having the code?
carharttkid629 is offline
post #7 of 7 (permalink) Old 02-02-2009, 02:36 PM Thread Starter
2nd Gen Guru
APPS codes (P0121, P0122, P0123). APPS codes will alow the truck to run but no throttle change.
P1689 No Comm between VP44 and ECM. The engine won't even start...
Human Verification
Error Codes Dump and Code Listing Mopar1973Man General Dodge Discussion 7 01-03-2010 02:13 AM
OBD Error Code Dumping and Reading Mopar1973Man 5.9L Cummins (1998.5-2002) 1 04-26-2009 12:54 AM
Error Code: PO 308 JoeDirte 1994-2003 7.3L Power Stroke 9 03-08-2008 11:55 PM
code problem, CONTROL MOD KAM ERROR?? brietwyk 1994-2003 7.3L Power Stroke 7 07-19-2007 02:08 PM
code p0603 internal kar error bunsorrou 1994-2003 7.3L Power Stroke 15 08-28-2006 11:40 PM
