P2509 code - TheDieselGarage.com
Thread Details Posted by 2blue11, this thread has received 2 replies and been viewed 8696 times.
post #1 of 3 (permalink) Old 09-05-2009, 11:19 PM Thread Starter
member
P2509 code
My check engine light came on this morning and i checked for codes and it had a p 2509. Anyone had this? I know its something to do with power to the computer. How can this be fixed?
07 2500 5.9 4x4, automatic, diablosport powerpuck, gutted stock intake with K&N filter, 2" leveling kit and i dont kno where that dang silencer ring went. More to come... Exhaust, CFM+, Predator stack, tires and wheels when the money permits
When you get done powerstrokin your duramax only the best is left CUMMINS
2blue11 is offline
post #2 of 3 (permalink) Old 09-08-2009, 03:43 PM
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
Check this thread. Dtc p2509
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline
post #3 of 3 (permalink) Old 09-08-2009, 04:32 PM
TDG Mafia - Booze Runner
Snowaholic's Avatar
Possible Causes
POOR CONNECTIONS AT THE BATTERIES
LOW BATTERY VOLTAGE
OPEN FUSED B+ TO ECM
OPEN GROUND CIRCUIT
BATTERY + SHORTED TO OTHER CIRCUITS
RETURN CIRCUIT SHORTED
BATTERY + SHORTED TO GROUND
INTERMITTENT CONDITION
I checked my Batteries, while they were a little low they were not the problem.. I've been having a problem with one my EGT Gauge and have concluded that there was enough of a Voltage short and it caused my Code.. It still crackles and I haven't been able to find a new gauge around here to replace it, but After clearing the code it hasn't come back.. I vaguely remember as I had the truck in the Key-On position the Electrical Crackle was louder than normal when I got the code...
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline
Human Verification
code p2509 lilrebeljames 5.9L Cummins (2003-2007.5) 11 10-08-2010 05:59 PM
Dtc p2509 Snowaholic 5.9L Cummins (2003-2007.5) 1 09-03-2009 01:14 AM
P1689 ERROR CODE - Cause of code Found! Mopar1973Man 5.9L Cummins (1998.5-2002) 6 02-02-2009 02:36 PM
p2509 dalton06 5.9L Cummins (2003-2007.5) 0 04-10-2008 08:38 PM
P2509? ovruigo 5.9L Cummins (2003-2007.5) 0 11-23-2007 02:24 PM
