When was egr introduced to cummins - TheDieselGarage.com
Thread Details Posted by 6litrefan, this thread has received 19 replies and been viewed 15328 times.
post #1 of 20 (permalink) Old 04-17-2010, 04:19 AM Thread Starter
Can you guys tell me when or what year egr was introduced into the cummins on the dodge trucks.....was it when they came out with the 6.7??? Cause i dont think the 5.9 had egr correct???.....and also when where the last of the 5.9's made....07?
6litrefan is offline
post #2 of 20 (permalink) Old 04-17-2010, 04:52 AM
Kummins's Avatar
You are correct. EGR came out in 07.5 on the 6.7. Last year for the 5.9 was 07.
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
Quadzilla Boost Fooler
S&B Intake
MBRP all the way back and "High Flow Cat"
6" Lift, 35" Toyo MT's, 20" Incubus wheels
Some Audio Goodies Too
MAY 2008 TDG Truck of the Month
Kummins is offline
post #3 of 20 (permalink) Old 05-06-2010, 02:33 AM
it didnt start until 04.5 when the changed the camshaft profile and introduced 3rd injection event....camshaft profile closes exhaust valve easrlier to hold in exhaust gases to produce an "in cylinder egr"
kubotaorange76 is offline
post #4 of 20 (permalink) Old 05-06-2010, 01:12 PM
MART5.9's Avatar
You are correct. A lot a people don`t know this. You can tell on a 06 like mine, by how fast the oil turns black after an oil change.
2006 3500 mega cab SLT auto.
Diamond eye turbo back, S&B cold air intake,62mm turbo, billet tranny, smartyJR....
Proud to now participate to global warming
EGR and DPF are the worst CRAP ever and the worst is still to come.....UREA !
MART5.9 is offline
The Following User Says Thank You to MART5.9 For this addition to TDG:
Kummins (05-08-2010)
post #5 of 20 (permalink) Old 05-06-2010, 06:25 PM
Kummins's Avatar
I didn't know this. Good to know although an in cyclinder process can't be tinkered with or have nearly the effect of an external. In other words pre 6.7 EGR is barely noticeable.
06 2500 Quadcab SLT
Billet Tranny
BD with Crazy Larry
S&B Intake
Kummins is offline
post #6 of 20 (permalink) Old 05-06-2010, 08:03 PM
That's one of the reasons ii did my cam , gets rid of it much cooler egt
post #7 of 20 (permalink) Old 05-07-2010, 12:27 PM
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
I didn't know this either.
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline
post #8 of 20 (permalink) Old 05-07-2010, 12:33 PM
theres a few good threads about it on DTR and CF with some links to literature from cummins talking about it
now if you buy a camshaft from cummins for your 03-04 motor you get the same grind as 04.5-07
The 9cm exhaust housing helps the "in cylinder egr" effect as well...
Camshaft was one of the best mods i have done, right there with turbo
post #9 of 20 (permalink) Old 05-07-2010, 12:40 PM
heres one http://www.dieseltruckresource.com/d...t=cylinder+egr
12 2500 st 6.7
99 3500 drw p24v
87 6.9 4x4 locked 60 front
78 f-150 4x4 lwb
The Following User Says Thank You to kubotaorange76 For this addition to TDG:
post #10 of 20 (permalink) Old 05-08-2010, 12:09 AM
MART5.9's Avatar
Ya but don`t worry about it at all. It`s nothing compare to an EGR soot at all. I traded my 07.5 6.7 for an 06 5.9, i did`nt want no soot anymore, i knew about this timing stuf before trading my 6.7.
What makes the soot coming from a real EGR system such a killer is the exhaust fume cooling down and turning to dry dust before re-entering combustion chamber . It does`nt happen this way with a 05-06 5.9 at all and it`s not considered as soot at all but only very small part of hot exhaust fume staying inside to go thru combustion once more. We have 3 old tractor trailer with detroit using a similar system and they all have over 650 000 miles on them and still run strong.With regular oil changes, your 5.9 is going to pump fuel FOREVER!!!
MART5.9 is offline
Human Verification
New Cummins SmokinCAT Medium and Heavy Duty 1 03-22-2008 02:26 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Diesel Conversion 0 05-23-2007 06:29 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Whats Been Sold 0 05-23-2007 06:29 AM
My Cummins cmnspwr General Dodge Discussion 15 01-27-2007 01:17 AM
05 cummins Diesel Freak Whats Been Sold 1 12-03-2006 03:58 AM
