Maximum tow capability - TheDieselGarage.com
Thread Details Posted by ovruigo, this thread has received 38 replies and been viewed 1722 times.
post #1 of 39 (permalink) Old 07-10-2007, 01:57 PM Thread Starter
TDG Mafia 23
ovruigo's Avatar
Images: 10
Can anbody tell me the maximum towing capability of an 08 F-450
TIA....
~C.A.~
06 5.9 3500 DRW auto w/ smarty
ovruigo is offline
post #2 of 39 (permalink) Old 07-10-2007, 02:10 PM
that totally depends on how you option it.
I think that the max for a properly equipped 450 is 24500lbs fifth wheel
Spatel23 is offline
post #3 of 39 (permalink) Old 07-10-2007, 02:17 PM Thread Starter
TDG Mafia 23
ovruigo's Avatar
Images: 10
That weight doesn't include the truck right. I could actually tow something that combined with the trailer weight to be 24500
~C.A.~
ovruigo is offline
post #4 of 39 (permalink) Old 07-10-2007, 02:26 PM
With a 2WD F450 w/4.88 gears you can tow a 24,500lb trailer (approximate).
The max GCVWR for the F-450 is 33,000lbs with 4.88's or 29,000 with 4.30's.
BONE STOCK
444turbodiesel is offline
post #5 of 39 (permalink) Old 07-10-2007, 02:27 PM Thread Starter
TDG Mafia 23
ovruigo's Avatar
Images: 10
Thanks fellas
~C.A.~
ovruigo is offline
post #6 of 39 (permalink) Old 07-10-2007, 04:24 PM
Mafia #42
HighTQCummins's Avatar
Location: Valley Forge PA/West Long Branch NJ (college)
Send a message via AIM to HighTQCummins
Does that mean you would need a CDL since its over 26,001#?
Hank
TDG and the Mafia lives on
TDG B.O.M.B. Squad #5
My Truck:2007 Toyota Tacoma V6 4x4
Diesel is in my blood, I guess you can call it a disease, sadly there is no cure for it, it's my cross I must carry
HighTQCummins is offline
post #7 of 39 (permalink) Old 07-10-2007, 04:27 PM Thread Starter
TDG Mafia 23
ovruigo's Avatar
Images: 10
Looks that way. Sweet, when I replace my truck my daily driver will require a CDL.
~C.A.~
ovruigo is offline
post #8 of 39 (permalink) Old 07-10-2007, 04:35 PM
Oil Burner
Are you going to drive them commercially?
Cattle-Dog is offline
post #9 of 39 (permalink) Old 07-10-2007, 04:45 PM
Oil Burner
One technicality that makes the whole thing moot anyway. The F450 has a GVWR of 14,500 lbs, which is well below the 26,001 limit for commercial CDL's. The 29,000 number is the GCWR.
post #10 of 39 (permalink) Old 07-10-2007, 05:03 PM
Haulin' Azz
BROKER's Avatar
If trailer is over 10,000gw then you need a cdl unless its an rv .
The F450 reqires nothing if its for personal use , use it commercialy and you need a health card . Hook a +10,000gw trailer to , you will need the cdl.
Dot is having a ball this season with the F350,CK3500 and W3500 .They are making them stick DOT# on them if they cant prove personal use.
BROKER is offline
Human Verification
