P0620 - Generator Control Circut - TheDieselGarage.com
Thread Details Posted by sacu, this thread has received 4 replies and been viewed 4821 times.
post #1 of 5 (permalink) Old 01-19-2010, 11:21 PM Thread Starter
sacu's Avatar
Has anyone had this problem yet? Headlights dim then get bright, dash lights shut on & off, radio shuts off and/or changes inputs. I'm also getting a alternator high voltage code.
08 Ford F350 TowBoss
Spartan Tuned
sacu is offline
post #2 of 5 (permalink) Old 01-20-2010, 02:27 AM
I Eat Rice
forcefed6.4ford's Avatar
nope
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #3 of 5 (permalink) Old 01-20-2010, 07:42 PM
Sounds like your control module on the alternator is on the fritz. This happened on my old fox-box
Crown Vic Guy is offline
post #4 of 5 (permalink) Old 01-22-2010, 10:08 PM Thread Starter
sacu's Avatar
Just got it back from the dealer, one corroded connection on the lower alternater wiring harness caused all of this. I would of thought that the second alternater would of picked up the load and I wouldn't of had any of these problems.
Spartan Tuned
sacu is offline
post #5 of 5 (permalink) Old 01-26-2010, 04:17 PM
interesting. are they both run through the same harness/wiring? or are they independent?
Human Verification
Injector Circut Low Codes...FICM??? Bane 2003-2007 6.0L Power Stroke 3 06-19-2009 01:54 PM
kohler generator /FS bobh Whats Been Sold 0 02-26-2008 08:41 PM
40KW generator 01duramax6spd Whats Been Sold 0 12-12-2007 11:07 PM
Need Generator Help Billysgoat The Parking Lot 2 09-04-2005 10:14 PM
