Cummins cpl 676 rebuild - TheDieselGarage.com
Thread Details Posted by Cummins5.9r, this thread has received 0 replies and been viewed 236 times.
post #1 of 1 (permalink) Old 11-24-2016, 12:54 PM Thread Starter
Okay so I need some help I'm rebuilding my cpl 796 back to a cpl 676 and swapping the cam now and am trying to get this motor to the 700 or 750 range now I have a few questions along the way
First I'll just tell you what I plan on doing, I'm swapping from the low flow cooling system and the water to air cooler and putting a n14 intake on instead and a CAC
I've talked to a really nice and help guy about the fuel part from diesel control in Ohio I think it's is and I believe we are going to do a set of injectors in the 250cc range and fuel pressure somewhere in the 250 to 300 range and run a hx60 or equivalent borgs turbo
Now my question is timing where do you guys thing would be a good place to set the timing to and how would I go about doing IE. do I need a different offset woodruff for the cam or will I get enough out of the follower gaskets.
And this will be a working truck in Illinois so it won't be running up any big mountains. thanks in advance
for the help
Cummins5.9r is offline
Human Verification
77 Mack 676 pump adjustments? nevrenufhp Medium and Heavy Duty 1 07-21-2015 02:46 AM
Cpl help for cummins ntc/nte 855 erf Medium and Heavy Duty 2 09-17-2012 07:37 AM
Cummins CPL 324 Big Cam 400 specs? kblackav8or Medium and Heavy Duty 9 06-12-2012 10:58 PM
Cummins CPL 1210 N-14 Problem 9200IH Medium and Heavy Duty 7 01-30-2011 01:01 PM
found cummins CPL 1551 190hp w/p7100 rustyrelic 5.9L Cummins 12 Valve (1994-1998.5) 7 07-31-2007 01:29 AM
