Coolant Flush Qestion - TheDieselGarage.com
Thread Details Posted by SLW, this thread has received 59 replies and been viewed 16953 times.
post #1 of 60 (permalink) Old 02-19-2011, 03:02 AM Thread Starter
SLW
At 103K my EGR cooler went out with that my HG's let go, thankfully no damage to any thing else.. I had an EGR Delete, new cooler, head gaskets and ARP's installed. Should I do the coolant flush routine that I have read about? My worry is that I will clog my my new oil cooler with the crap that is still in the engine. Should I just install my new coolant filter and go with it?
I'm the original owner.
2005 Lariat FX4 Crew Cab,
ARP Studs,
Sinister EGR Delete,
Sinister coolant filter,
Fabtech leveling kit,
4" Turbo back exhaust
SCT with Looney Tunes by Vivian @ Quicktricks
SLW is offline
post #2 of 60 (permalink) Old 02-19-2011, 07:43 PM
We just flushed my dad's '03 with Fleetguard Restore (alkaline) then Restore Plus (acidic, similar to VC-9). I was also concerned about knocking too much crap loose so we did a milder mixture of each, just two quarts instead of the full gallon of each. It takes lots of water flushes after each, so don't bother with distilled water until the final two flushes. We have a distiller and after going through about 25 gallons gave up and used tap water, then did a final flush with distilled. Pulling the block plugs lets a lot more drain out too, you only get about half when you just drain the radiator.
As far as the oil cooler efficiency goes, I was monitoring it during each flush with AE on high idle. After the Restore, I started to see abut 7-8 degrees difference, then after the water flushes, Restore Plus, and more water, they were within 1 degree again.
cartmanea is offline
The Following User Says Thank You to cartmanea For this addition to TDG:
harry6.0 (02-20-2011)
post #3 of 60 (permalink) Old 02-19-2011, 08:25 PM
I use Arm and Hammer washing Soda and Dawn dishwasher soap if there is oily residue. The fleetguard products are great, but why pay the extra cash and from what I have seen the arm and hammer removes the scale build up even better than anything I have ever used. Dawn is by far the best at getting any oily residue out. If it is your daily driver, fill it up and take it to work, drain the block, if you have access to an air compressor blow out the heater core. I mix it up in a pail with warm water and mix with a paint mixer then pore into another container, to fill the unit. top it off in the morning you want it as full as possibler so it blows out the overflow, cleaning the recovery tank. If you do it on a cement driveway, or into a drain pan you can see the crud coming out. disposal is pore it on your lawn when it cools it is fertilizer. You keep doing it until it comes out clean it does take a while.
Johnp3 is offline
The Following 2 Users Say Thank You to Johnp3 For this addition to TDG:
harry6.0 (02-20-2011), Ron33 (03-03-2012)
post #4 of 60 (permalink) Old 02-20-2011, 10:55 AM Thread Starter
SLW
Thanks! now I need to figure out where the block plus are.
ARP Studs,
SLW is offline
post #5 of 60 (permalink) Old 02-20-2011, 02:48 PM
harry6.0's Avatar
Good info Cartmanea. Just curious though, what type coolant did you refill with?
Harry
harry6.0 is offline
post #6 of 60 (permalink) Old 02-20-2011, 03:42 PM
We used Zerex HD Extended Life, it's a red ELC similar to CAT and Fleetgard ELC. Since that is what International specs for the motor, I figured we couldn't go wrong, and get rid of the Premium Gold crap with the oil-cooler-blocking silicates.
Another benefit, the red coolant is much easier to see inside the yellowed degas bottle. With the Premium Gold in there you couldn't hardly see where the level was.
post #7 of 60 (permalink) Old 02-20-2011, 03:51 PM
I just flushed my engine at 73000 with restore and VC-9.
I put back the Premium Gold because of warranty reasons.
I checked my EOT vs ECT and it never exceeds 7 degrees, so I think the oil cooler is still flowing enough to get me by for awhile.
I was thinking of switching over to ELC when my warranty ends.
Does anyone know how the ELC stacks up on corrosion protection?
In the descriptions of the silicate type coolants they seemed to say that the silicate coats the metal parts and in this way protects them.
06' F250 Mods:
Performance related:
-K&N E-0780 Air Box, ZooDad Mod
-Garrett Powermax Turbo, CFM+ Smallmouth Intake Manifold
-Blue Fuel Pressure Spring, Large fuel lines from pressure regulator to heads
-MBRP 4" Turbo back exhaust; cat installed
-SCT SF3 Tuner w/SRL custom tunes from Matt at GearheadAutomotivePerformance.com
Reliability Mods:
-Refurbished 50 volt FICM, Eliminated STC fitting, upgraded stand pipes and dummy plugs, Bulletproof Diesel EGR cooler, upgraded turbo oil supply and drain
-Oil change rotation; 5k-5W40/5k-15W40/5k-15W40
--Rotella T5 or Valvoline Blue Extreme 5W40, Rotella or NAPA 15W40, Archoil 9100 friction modifier (16 ounces to crank case; 10 ounces to each differential)
--2/3 Qt. tcw3 2 cycle oil per tank Power Service (5 oz. Stanadyne every tank)
-Cooling system flush with Restore and VC-9 @ 73,000 miles w/new thermostat
-Eliminated clunk while sitting at a light (75,000 miles); Lubed rear drive-shaft spline with Ford lubricant; Symptom returned at 100,000 miles...re-lubed at 112,000 miles....wow!! it's so smooth again.
Miscellaneous:
-1/2" shim on carrier bearing mount
-Batteries:
--Original Motorcraft lasted 4 1/2 years
--AutoZone Duralast Gold lasted less than 3 years
---(with 2/0 cables between + terminals)
--Still on 2nd set of Autozone Gold (replaced free)
-Alternator:
--DC Power 185 amp
Future Mods:
-Teflon sway bar bushings
-Moog Ball Joints (originals seem to be holding tight at 108,000 miles; it's just a daily driver, so this seems to make sense)
-Cooling system filter
-OEM HG/ARP studs
bustedknuckles is offline
post #8 of 60 (permalink) Old 02-20-2011, 04:15 PM
IMO, the ELC is better in every way. They just use different corrosion inhibitors than silicates. In our engines, the silicates can precipitate out of the coolant at high temps, such as in the EGR cooler, and this creates the sludge that everyone finds in their plugged up oil coolers.
post #9 of 60 (permalink) Old 02-20-2011, 09:11 PM
OK. I guess I will switch over as soon as my warranty is up, however, I may extend the warranty if I think it will be worth the money. The Ford 48 month 48,000 Baseline Extended Warranty looks pretty attractive to me at this point. It has the extra coverage I'm looking for. For example it covers the injectors and high pressure oil pump, as well as the oil and egr coolers. They will need to examine my truck before they will sell it to me. And before I buy the extended warranty it I will make sure they will still honor the warranty if I do my own service. I'm pretty sure they will, since it will most likely be handled the same way the new car warranty was handled. The dealer that you take it to has a lot to do with your experience, and the way my dealer handles my service is not perfect, but it's pretty good.
06' F250 Mods:
Reliability Mods:
Miscellaneous:
-Batteries:
-Alternator:
--DC Power 185 amp
Future Mods:
-OEM HG/ARP studs
post #10 of 60 (permalink) Old 02-20-2011, 10:30 PM
International built this motor and it is ELC they use. But maybe Ford knows something International doesn't. Trust me they (ford) don't.
lenzhotrod is offline
Human Verification
Coolant Flush fordt Duramax 2006-2007(LBZ & LLY) 2 04-12-2010 12:48 PM
Coolant flush toddsnorthriver 2003-2007 6.0L Power Stroke 13 12-17-2009 09:46 AM
coolant flush? outlaw6oh 2003-2007 6.0L Power Stroke 3 02-14-2009 10:44 PM
coolant flush dalkins1 5.9L Cummins 12 Valve (1994-1998.5) 3 11-10-2007 06:25 PM
Coolant Flush? Partz 2003-2007 6.0L Power Stroke 7 03-21-2006 02:48 AM
