Fan speed sensor - TheDieselGarage.com
Thread Details Posted by jdydiesel, this thread has received 7 replies and been viewed 2662 times.
post #1 of 8 (permalink) Old 04-10-2011, 11:13 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
Fan speed sensor
So I have a Fan Speed Sensor failure code. So my question is where is the FSS? Is it attached to the front of the fan, where the wires attach to the clutch? If so what is the easiest way to get to it? I haven't been into these 6.0l much, so any help would be great. Thanks
Jason
02 Excursion 4x4 Limited 7.3l. Banks Stinger Plus system
06 F-350 4x4 CC LB Tow Boss Lariat 6.0l auto. Banks PowerPDA, Banks SpeedBrake, FICM Atlas 40 Tune, ARP Studs, PowerMax GT3788VA turbo, Homemade coolant filter, EGR valve delete spool, Monster Exhaust, K&N Cold air intake, Husky mudflaps, Line-X bed liner, Recon lights, TUNED BY DFUSER.
72 F-250 Gasser.Looking for an 05-07 6.0l, 5R100 and Dana 80 to install
jdydiesel is offline
post #2 of 8 (permalink) Old 04-10-2011, 11:17 PM
Trip's Avatar
I have had that code for over a year now, and when I have asked in the past I recived little response.
03 F-250 Lariat 4X4 6.0L- NEW ID PROGRAMED FICM 105,000 (sitting on shelf while I figure out whats going on with the turd...furd) wheel berring 103,000 Dfuser coolant filter104,000, EGR plug104,000mi, y-pipe109,800mi,bootlegged 3.5" straight pipe110,000, rotors and pads on all 4 points 110,400mi, 35X12.50R17 Toyo M/T@ 111,300 ICP sensor 115,000
WALNUT (anti-ACORN) member#23
Trip is offline
post #3 of 8 (permalink) Old 04-10-2011, 11:23 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
Have you noticed any issues with cooling? I'm taking a trip this summer pulling the trailer and don't to have any issues?
Jason
post #4 of 8 (permalink) Old 04-10-2011, 11:26 PM
Trip's Avatar
No it stays where it should, I still hear it kick on low from time to time but AE says its right where it should be. I had high readings for a while but after I changed my alternator it reads where it should, I belive the input voltage was incorrect giving a high reading.
Trip is offline
post #5 of 8 (permalink) Old 04-10-2011, 11:31 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
What's AE?
Jason
post #6 of 8 (permalink) Old 04-10-2011, 11:45 PM
Trip's Avatar
Auto Enginuity
Trip is offline
post #7 of 8 (permalink) Old 04-11-2011, 03:02 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
Oh. I need to get one of those. It would help with diagnoses.
Jason
post #8 of 8 (permalink) Old 04-11-2011, 05:29 AM
Trip's Avatar
I regret geting it, I now know every time something gose wrong on the truck, now I am always turning a wrench. It tells me everything, couldnt go without it...
Trip is offline
Human Verification
speed sensor A vcassens 2003-2007 6.0 Tuner Forum 2 06-20-2010 12:36 PM
Possible Speed Sensor maxxis_mudder 2003-2007 6.0L Power Stroke 1 02-26-2008 01:48 PM
speed sensor katzer 1994-2003 7.3L Power Stroke 1 02-18-2008 11:04 PM
Speed sensor imported_bsutton2000 1994-2003 7.3L Power Stroke 1 10-03-2007 03:20 AM
Speed Sensor fuzzys69 1994-2003 7.3L Power Stroke 4 05-22-2006 03:58 AM
