6.0 starter bolt sizes - TheDieselGarage.com
Thread Details Posted by rickou812, this thread has received 6 replies and been viewed 1395 times.
post #1 of 7 (permalink) Old 03-04-2017, 05:40 PM Thread Starter
THE SILVER BULLET
My 2003 f250 stopped turning over, found the that the starter bolts had backed out. The lower bolt is gone, the top bolt is broke and the middle bolt has what is left of the broken starter flange.
So after searching, I have this is a common issue and the question about bolt sizes asked a hundred times..but I have not been able to find post giving the actual bolt sizes...especially the bottom bolt...other than it is an odd size...lol
Would someone be so kind to give all three bolt sizes and make it a sticky....lol
Thanks,
Rick
2003 F250 CC 2WD 6.0 January build date. >200,000 miles and running strong.
MODS include: Fuel system with adjustable regulator, SCT, 4" turbo back.
CAN YOU KEEP UP ??
rickou812 is offline
post #2 of 7 (permalink) Old 03-04-2017, 10:19 PM
Pretty sure these are the sizes:
Starter bolts:
2-m8x1.25 40mm w/ a 13 mm head (top two) - grade 8
1-m12x1.75 40mm - grade 8 - can't recall the head size.
Use locktite on the larger bolt to keep it on (low strength). The theory is that the aluminum threads set the torque spec and that the spec is insufficient torque (don't want to strip the aluminum threads) to "stretch" an M12 bolt (tty bolt).
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline
The Following User Says Thank You to bismic For this addition to TDG:
rickou812 (03-05-2017)
post #3 of 7 (permalink) Old 03-04-2017, 10:45 PM
Torque value in the WSM is 25 N-M (18 ft-lbs) for the three bolts.
Solenoid nut torque spec - 6 Nm or 53 in-lb
Positive cable nut torque spec - 12 Nm or 9 ft-lb
I believe that the M12 bolt also has a 13 mm head.
Mark
bismic is offline
post #4 of 7 (permalink) Old 03-05-2017, 01:32 PM Thread Starter
THE SILVER BULLET
Thanks Mark,
Just for future purposes, I was able to pick up bolts from tractor supply in the following sizes:
M8-1.25 x 40mm
M12-1.75 x 60mm
I went to 60mm and plan to place a lock washer on the bolt.
Rick
CAN YOU KEEP UP ??
post #5 of 7 (permalink) Old 03-05-2017, 06:03 PM
Good idea on the longer bolt!
Glad you got it!
Mark
bismic is offline
post #6 of 7 (permalink) Old 03-05-2017, 10:59 PM Thread Starter
THE SILVER BULLET
Just a follow up,
the M12-1.75 x 60mm is on the long side, but does not go into a blind hole, the extra just passes through the starter.
A M12-1.75 x50mm would be perfect with a split washer/lock washer, however, 50mm length is not common hardware store item.
Another option, a nut could be used on the backside of the 60mm long bolt for insurance purposes
CAN YOU KEEP UP ??
post #7 of 7 (permalink) Old 03-06-2017, 12:41 AM
You could always cut a 60mm bolt down. Put a nut on it at the proper length and then cut it. The nut protects the threads during the cut and then dresses them when you remove it.
Found this video, it has good description on the installation at the end.
https://youtu.be/r7JwYkvvHVk
Mark
bismic is offline
Human Verification
Tire sizes SuperTaz 6.7L Cummins (2007.5-2011) 4 04-20-2012 06:55 PM
speaker sizes robfrass 5.9L Cummins (2003-2007.5) 2 12-18-2009 03:13 PM
What would cause the starter bolts to break and the starter to break in half? Rgdl 2003-2007 6.0L Power Stroke 15 06-20-2009 01:18 AM
starter or starter selnoid? 96 stroker 1994-2003 7.3L Power Stroke 6 01-31-2008 03:23 PM
Tire sizes powerstroke2003 General Ford Truck and Excursion 6 12-02-2007 07:14 PM
