Overheating when pulling? - TheDieselGarage.com
Thread Details Posted by STV, this thread has received 16 replies and been viewed 1236 times.
post #1 of 17 (permalink) Old 02-21-2007, 05:32 AM Thread Starter
STV
RC51
First off, I have head studs, just got the EGR replaced at dealer after blowing coolant out of overflow and exhaust. So, I towed my 12k trailer and not only did I blow coolant out of the overflow but, my temp gauge would go on up to HOT for about two seconds and then race down to the middle where it belongs. I thought it could be because of the stupid EGR crap so I bought the up pipe from Elite to stop the hot exhaust gas from entering the EGR. Just got back from towing my trailer again and it's the same. Doesn't matter if I'm under a load or not, it still does it about every 15 minutes while towing. Never does it while not towing. I'm still blowing coolant as well. Could the temp issure be a bad thermastat? Do the 6.0's have thermastat issues? My other concern is that it still is blowing coolant even with the studs and EGR delite up pipe. I haven't heard of anyone still having coolant issues with studs and up pipe. Any ideas? Any help would be great. Thanks
2003 RC51,1995 STV EuroSki 2.5 Merc, 2001 CR500
Special Construction TRX510R,2003 Sierra 28' toybox
2005 Harley Davidson Ripped off 10/18/07 Blue
8" Four link Rize lift, 37's on 24's,4:56 Gears, Head Studs, Elite EGR Delite Up Pipe, Elite SCT,Hog, AFE #1
Ridiculous Sound system, Kodiac steps
2008 FX4 Fully Loaded W/Sunroof Silver, Black Leather. DPF Sucks! Painfully Slow!
STV is offline
post #2 of 17 (permalink) Old 02-21-2007, 05:45 AM
i know it sounds too easy,, but alot of people have had success just replacing thier coolant cap with a new one. someone had a dealer test theirs and it was only holding 12psi and a new one is suppose to hold 16psi or something like that.. i believe they are less than 8 bucks new from the dealer.
2004 F-250 Harley Davidson Crew Cab 6.0
Airraid Intake, Innovative Sct Xcal2, MBRP 4" Turbo Back.
Everything Else Stock.
Average Fuel Miliage if i baby it 11.5 mpg WTF!
:sofa
bigguy75inches is offline
post #3 of 17 (permalink) Old 02-21-2007, 07:28 AM Thread Starter
STV
RC51
At 8 bucks it can't hurt to pick one up. I'll try it. The only thing is that it only does it when I tow. So, I'll have to wait two weeks until I tow again to see if it worked. Thanks
STV is offline
post #4 of 17 (permalink) Old 02-21-2007, 07:39 AM
Chitowns Biggest Baller
6.4lkid's Avatar
My truck was only overheating when towing to, replaced the gaskets, put studs in never had a problem since. When you did the studs, did you replace the head gaskets
Formerly 6.0lkid
2008 F250 FX4 Loaded
SCT TUNED
6.4lkid is offline
post #5 of 17 (permalink) Old 02-21-2007, 02:48 PM
Morpheus cycles's Avatar
Low pressure can cause the coolant to boil at a higher temp. as each extra psi of pressure in the cooling system helps raise the boiling point as well as the 50/50 mix of coolant and water. You can also add the (Water Wetter) additive to the cooling system which will add to the boiling boint and increase the cooling effcenicy of the mixture.
Jay
11 GMC 3500 4x4 SLT Crew Cab
Dually club #78
Singles #19 Yeah I drive a Jeep too.
86 CJ7 Rebuilt from the frame up as a rockcrawler
Morpheus cycles is offline
post #6 of 17 (permalink) Old 02-21-2007, 03:09 PM
jeez ive always used the water wetter in all my vehicles and since ive had my diesel for some reason never thought to use it. ill have to go get some and put it in.
hotshot4819 is offline
post #7 of 17 (permalink) Old 02-21-2007, 03:32 PM Thread Starter
STV
RC51
Studs went in at the dealer. The dealer would not use the gaskets I provided. So, they used new stock Ford gaskets when they put the studs in. It was about 15,000 miles ago. When I first put them in I didn't have this hot cycle coming and going while towing. It seems odd to be because I can be cruising down the highway @ 2,250 RPM with EGT's below 800 and watch the temp gauge go on up to the "H". About one second later the check gauge idiot light comes on and then by about one more second later the gauge goes right back down the the middle. My first instink says thermastat. But, if it was the thermastat wouldn't it do it while not towing at well? So, now I really don't know what it is.
STV is offline
post #8 of 17 (permalink) Old 02-21-2007, 03:50 PM
It could possibly be the stock gaskets. I had the same problem with my truck prior to installing Hypermax gaskets and ATS studs. Sense then I haven't had any pukeing or overheating while towing.
Jay
Dually club #78
post #9 of 17 (permalink) Old 02-21-2007, 04:49 PM
Rollin 41's
Can you hear the fan engaging? I had this problem and the wires to the fan clutch were broke.
05 Harley Black w/flames, 10.5" Lift, 41" IROKS on 20x12 KMC Rockstars, 4" Magnaflow Duals, AFE, 5.13 gears,Compound Turbos by Redneck6.0L, Hypermax Injectors, Banks Intercooler, MSD Propane Injection, ARP Headstuds, Hypermax Headgaskets, Race Trans by N.A.D.P., Suncoast T/C, Tuned By Innovative Diesel
Retorical is offline
post #10 of 17 (permalink) Old 02-21-2007, 11:30 PM Thread Starter
STV
RC51
Yes, fan comes on quite a bit. Actually more than it ever did with my 04'. That may be because of the fact that it's getting hot. But, the fan coming on doesn't seem to have a factor when the temp drops real fast just after getting in the red zone.
STV is offline
Human Verification
