Blowing coolant/overheating-need help - TheDieselGarage.com
Thread Details Posted by Texcursion, this thread has received 16 replies and been viewed 1481 times.
post #1 of 17 (permalink) Old 12-18-2007, 05:49 PM Thread Starter
Here is my latest 6.0 story. 2005 F350 6.0 Auto 4x4. Went to dealer at 17k for blowing excessive coolant while towing my RV. Got new Ford gaskets and head studs. Didn't tow much more until ~33k miles. By not towing much I mean over ~6k pounds. Started towing again and it started blowing coolant again. If I tow more than 10k lbs it will blow coolant and overheat. In total it has been in and out of dealer ~5 times for this issue and has received new:
Head gaskets
Thermostat
Cooling fan
Radiator
2 EGR coolers
2 EGR valves
oil cooler
coolant bottle and cap
It is still blowing coolant and overheating even though the coolant level is way below the add mark. Dealer doesn't know what else to do and they say Ford Tech support doesn't either. They are requesting a Ford rep come in person and check it out.:
Do you guys have any other ideas to look at?:shrug:
I know you guys see a lot and may have some recommendations. I traded a lemon 04 6.0 Excursion at 20k miles for an even longer laundry list of issues. I took a big hit on the trade in just trying to get rid of it and I'm not going to take a loss twice for the 6.0 crap so I need some help to diagnose or give it back. :mafia
Sorry, my questions turned into a rant but I have about lost it on this reoccurring nightmare.:givemebeer
Also in it's life, the truck has had a new turbo, 2 or 3 new shift solenoids, an AC controller face, 2 new batteries, fuel pump and 4 injectors. It still won't start below freezing without plugging in the block heater. All in 45k miles.
I am at a loss.
Thoughts?
GONE 04 Excursion 6.0 4x4 EB (POS lemon is out of here!)
05 F350 CC Dually 6.0 4x4 Lariat
06 F250 CC SB 6.0 4x4 Lariat
Texcursion is offline
post #2 of 17 (permalink) Old 12-18-2007, 05:59 PM
I've had the same problem, 4 egr cooler, and now I have arp studs. I'd say it could be another egr cooler or oil cooler. Is it smoking alot when you start it first thing when it's cold?
05 F-250 FX44"superlift, 35" pirelli scorpion ATR"S, sirius satellite radio, 1 sony 10" with 1k watts. sct with spartan and Doug's tunes, bullydog outlook, coolant temp, Egrcooler delete, coolant filter, 4" exhaust to 5" stacks, B&W gooseneck hitch, limo tint, ARP studs. AFE stageII intake with PG7, VIPER 5900SST
RIDIN' DIRTY member #23
Bomb Squad member #49
Running motor and trany with all wires, computers, ic, programmer and outlook will be forsale! PM with offer.
stacks is offline
post #3 of 17 (permalink) Old 12-18-2007, 06:27 PM
SLAPS President
teamroper60's Avatar
Images: 9
All of the usual suspects have been addressed it seems, so to me it sounds like either your heads are warped or the block is not true. I suspect the tech that did the work did not check this when he made the repairs....
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #4 of 17 (permalink) Old 12-18-2007, 06:42 PM Thread Starter
No smoke when it starts but it knock and pings when it's cold like it's missing on one cylinder. When running temp, it starts great.
Tech checked the heads but not the block. He said they have a tool for checking the heads but not the block so it wasn't done.
post #5 of 17 (permalink) Old 12-19-2007, 01:39 AM
LokiWolf's Avatar
He didn't have a tool??? Its called a straight edge...
It sounds like you have multiple issues. I would assume a lazy injector would be the cause of the cold start issues, but it could also be due to another compromised Head Gasket...:shrug:
2006 F250 CC SB 4x4
4.5 Icon 4-Link, TEI Spacers, and 5 Inch rear Springs.
Farmboy Fabrication Traction Bars.
SCT XCalII tuned by GoGoDiesel, DJ's, and Spartan...
LokiWolf is offline
post #6 of 17 (permalink) Old 12-19-2007, 02:02 AM
pinging sounds like an injector issue. You got a new coolant bottle cap but, did they change out the bottle itself? If it has new egr and oil coolers it sounds like teamroper60 said either the heads or block.
stacks is offline
post #7 of 17 (permalink) Old 12-19-2007, 02:19 AM
Dually Club #3
jdydiesel's Avatar
Sounds like you have gone to the same dealer as I have, one that has no idea what they are doing just throwing parts at it. I would try another dealer if you can.
Jason
02 Excursion 4x4 Limited 7.3l. Banks Stinger Plus system
06 F-350 4x4 CC LB Tow Boss Lariat 6.0l auto. Banks PowerPDA, Banks SpeedBrake, FICM Atlas 40 Tune, ARP Studs, PowerMax GT3788VA turbo, Homemade coolant filter, EGR valve delete spool, Monster Exhaust, K&N Cold air intake, Husky mudflaps, Line-X bed liner, Recon lights, TUNED BY DFUSER.
72 F-250 Gasser.Looking for an 05-07 6.0l, 5R100 and Dana 80 to install
jdydiesel is offline
post #8 of 17 (permalink) Old 12-19-2007, 02:32 AM
I totally agree!!! I am so fortunate to have a great dealer here local to me that does alot of diesel truck repairs. JJ
EDIT I see you are in N Texas. What area? If you are close I can get you the name of an awesome dealer in Ft Worth.
Hardline is offline
post #9 of 17 (permalink) Old 12-19-2007, 04:54 PM
Head gaskets
Thermostat
Cooling fan
Radiator
2 EGR coolers
2 EGR valves
oil cooler
I am at a loss.
Thoughts?
I have the exact same problem on my 05 I have had everthing replaced same as what you have listed. But I have arp studs, egr delete and she still pukes and over heats. I am just going to beat the hell out of the truck and pull 30000 gcvw as usally and blow the motor and start fresh. Am I pissed yes But I love fords trucks And no matter how bad It comes too I will never be caught dead in a chevy or a dodge.I am going to build the new motor better.
I am going to do the elite coolant lines to the back of the heads, Stand alone oil cooler, Completley remove the Egr cooler, H-11 studs with Fire ring heads,Bigger radaitor.
[/B]2004 F-350 Lariat 4x4/CC/SRW/6.0 PSD
18 Inch Suspention with Atlas Springs,Cross Over Sterring With Ram Assist, 6 Chrome 2.5 Kings Piggy Backs, Ladder Bars Front And Rear With,Heims,Custom Cross member,Re-Indexing Ring On Transfer Case,5.13 Yukon Gears, Detroit Locker Front and Rear, High Angle Driveline Long Slip Front Shaft, High Angle Driveline Two Piece CV Rear Shaft, AMP Research Steps, RBP Turbo Back Exhaust With 5 In Tip,AFE Intake, Banks Intercooler,03 Turbo,Heads Ported & Polished By John Wood,ARP Headstuds,EGR Delete,ZEX Nitrious,SCT By John Wood, Mag-Hytec Front & rear Diff Cover, Mag-Hytec Trans Pan ,3 Gauge Pilliar, Dana 80 Rear Axle, 22.5 Super Single Alcoas With 45 Inch Tires, 2008 Front Clip![/B]
2005 F-350 Lariat 4x4/CC/Drw/6.0 psd/4.10 Rears
Airaid Intake,RBP Turbo Back Exhaust,ARP Studs,SCT By John Wood,Banks Intercooler,Edge Juice Platinum Gauges Only,EGR Delete,2.5 DR Levling Kit,On Black KMC Rockstars,Pulls 2006 Cl 4005 Weekend Warrior
GCVW- 33,585 pounds Loaded
pics http://community.webshots.com/user/rbp04
760 PSD is offline
post #10 of 17 (permalink) Old 12-20-2007, 01:30 AM
if it still pukes with the egr blocked off I'm guessing that would be the oil cooler? What else is there to make it puke?
stacks is offline
Human Verification
