6.0 turbo boot fixes?? help!! - TheDieselGarage.com
Thread Details Posted by 2008TT450, this thread has received 2 replies and been viewed 3318 times.
post #1 of 3 (permalink) Old 08-27-2009, 11:09 PM Thread Starter
ok im a duramax guy some im not on here often i used to be when i got my 6.4's but i stopped caring about those performance wise.. lol
ok so here we go vendors this is for you i need a new boot that clamps on the turbo on my 6.0 powerstroke chase truck.. it has the banks high ram and intercooler kit so im told this boot is a banks peice only so can i buy it seperately from anyone?? its saturated with oil and torn and keeps popping off! i need some help on a solution for this..
thank you..
also is it normal for a stock 6.0 turbo with a banks wastegate to make a barking sound whenever you let out of the gas once the turbo is spooled up. aka turbo bark but it does it all the time also with out a trailer and only under a small load..
Trucks:newest addition: 2003 4 door long bed lb7 duramax 5 speed alli. 4x4. white paint 9 inch cst lift. bfg 37 mud terrains. real robby gordon beadlocks black with polished beadlock ring. white tailgate handle white escalade handles. billet grill. 4 inch mbrp turbo back muff delete. edge chip, afe intake. amp steps. dual bilstein 5100s in front and bags and bilsteins in the rear. leather. absolutely love it!!!! FIRST BOWTIE DIESEL!!!!
early 03 f-550 white custom fitted bed 7.3 rbp 5 in. tb. worthless edge. airaid intake.
entertainment:7 in. kenwood in dash in rear 15 in. myron davis flipdown sub kicker L7 12 with 1500 watt kicker amp.
08 f-450 4x4 afe sct extreme: with 4.88's king ranch white all lites clear loaded
08 f-350 cc lb 4x4 afe sct extreme 3.73's king ranch white loaded
2008TT450 is offline
post #2 of 3 (permalink) Old 08-27-2009, 11:16 PM
lilpooh's Avatar
The 6.0 is a vgt, I don't think the make a wastegate for it.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #3 of 3 (permalink) Old 08-28-2009, 12:50 AM
********* and Mafia #90
Bcarriveau's Avatar
thank you..
like a Flutter? yes. 6L turbo fart. ..
check these guys out for a Boot, just give them a call with demensions you need. i bet they fix you right up http://www.turbohoses.com/index.html
100K miles on 4/7/2010
2005 F250 FX4 Supercab Shortbed
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
Human Verification
keeping boot on turbo?? 2008TT450 2003-2007 6.0L Power Stroke 8 08-13-2009 02:56 PM
blowing my boot DodgeThis 5.9L Cummins 12 Valve (1994-1998.5) 4 05-11-2009 11:54 PM
Lets talk coolant problem fixes/preventions LovinPSDs 2008-2010 6.4L Power Stroke 68 03-02-2009 10:48 PM
Wekiwa's magic exhuast fixes Wekiwa 2003-2007 6.0L Power Stroke 6 07-17-2006 03:06 PM
need a tie rod boot. 2towrjp 2003-2007 6.0L Power Stroke 3 05-26-2006 01:33 PM
