6.0 cold start/ rough run - TheDieselGarage.com
Thread Details Posted by big_shark, this thread has received 33 replies and been viewed 14183 times.
post #1 of 34 (permalink) Old 01-13-2010, 06:43 PM Thread Starter
My 04 never had any issues until this winter. It wont start unless I cycle the glow plugs 4 times. Then it runs incredibly rough and wont get out of its own way until it reaches full operating temp. No other start issues after initial startup. Any ideas??? Straight exhaust, AEM intake, Hypertech module
big_shark is offline
post #2 of 34 (permalink) Old 01-13-2010, 07:26 PM
The DUDE!!
sprman's Avatar
I had the same issue and fixed it with some REV X additive. Other people have gotten a new flash from Ford and fixed it as well.
2005 F-250 CC FX4 - bought it, changed some stuff
Eighty Sixed member - #3
Ridin' Dirty - #26
"All the oil is in TEXAS, but the dipsticks are in DC"
"If Obama is the answer, it must have been a stupid a** question......"
sprman is offline
The Following User Says Thank You to sprman For this addition to TDG:
big_shark (01-14-2010)
post #3 of 34 (permalink) Old 01-13-2010, 07:33 PM Thread Starter
I heard of the flash from ford, i have never had mine flashed or updated at all. Where is the REV X additive sold?
post #4 of 34 (permalink) Old 01-13-2010, 09:34 PM
lilpooh's Avatar
How cold are we talking? When were your oil and fuel filters changed last? What weight motor oil are you using? How old are the batteries? IMO, start with the basics and go from thier.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #5 of 34 (permalink) Old 01-13-2010, 09:44 PM
GOS
Supporting Vendor
GOS's Avatar
It could be alot of things that have been covered above. Voltage battery problem, oil quality and viscosity problem, Injector issues, Flash program issues. I'm following the Rev X stuff, it sounds very promising and could save alot of people some money.
Contact 1-800-620-4467
Fax 1-406-222-4926
aden@gosperformance.com
GOS is offline
post #6 of 34 (permalink) Old 01-13-2010, 11:36 PM
Trbotime's Avatar
Could be a bad FICM. That problem seems to be going around lately!
2006 F-250 Lariat, C/C, 4x4, 3.73's, 4" custom turbo back RPM exhaust, hollowed cat, no muffler, zoodad mod, 20" XD Series KMC Hoss wheels w/ BFG a/t's
Trbotime is offline
post #7 of 34 (permalink) Old 01-14-2010, 02:00 AM
plowin4u's Avatar
How about bad glow plugs?
Cliff
2004 F250 6.0 diesel
Foose wheels w/ bridgestone duelers, 2 1/2 in. leveling kit, skyjacker shocks, recon led lights, jvc radio w/ kenwood amp, mtx subs, more to come.
plowin4u is offline
post #8 of 34 (permalink) Old 01-14-2010, 05:38 PM Thread Starter
My batteries are less than a year old, oil and filters were changed right before christmas, Rotella 15-40. I was about to order the glow plugs when I started hearing about the flash update. Local dealer is $120 for the latest update. I will try to get my truck down next week, and see where we go from there. The temp here the last couple weeks has been around 15-20 degrees in the morning.
post #9 of 34 (permalink) Old 01-14-2010, 07:43 PM
stmline's Avatar
I have always run amsoil series 3000 and never had a problem, had to change oil before a family crisis trip no choice and to leave asap so I used a competitors oil. I now have a hard start problems with mine when its cold she doesn't want to start and also runs like chit for a few. I have never plugged my truck in until now and I will be going back to amsoil. Have you made any changes to your oil or anything lately??
THANKS TO ALL OF OUR TROOPS THAT ARE FIGHTING FOR OUR FREEDOM.
2006 6.0L F350 4x4 Crew CAb SWB Build Date 4/06 Job #2
Arp Head Studs, Welded EGR, AirRaid, BDS leveling kit w/ Mono Tube Shocks, SCT TSX Tuned by Innovative Diesel
ITS BLOWIN COAL
stmline is offline
post #10 of 34 (permalink) Old 01-14-2010, 08:34 PM
blue smoke
starts fine runs fine until 60 around 18 and 2000 then it stats missing wants to shut down blue smoke i can pull over and wait 2 min as long as i keep it runing
and it will clean up and if i rev it up a few times a bunch of blue smoke comes out and hit 60 0r 70 all over again in can an injector put in to much fuel or can the oil from the injector leak in to the cylender getting p0226 more than any other coad and by the way 6.0 powerstokes SUCKS
6.0 sucks is offline
Human Verification
For those with Factory Pilot Injection trying to diagnose rough idle/cold start PSDPlayer 2003-2007 6.0L Power Stroke 1 01-14-2010 08:40 PM
Rough start and white smoke at cold start? bassn_07 2003-2007 6.0L Power Stroke 11 03-02-2008 10:57 PM
cold start, rough idle fix billymac61 2003-2007 6.0L Power Stroke 8 11-23-2007 04:42 PM
Rough idle and smokes during cold start ups. bigbore 2003-2007 6.0L Power Stroke 8 08-03-2006 02:45 AM
Rough/Miss on first, cold start of the day Extended Power 2003-2007 6.0L Power Stroke 12 11-11-2005 10:38 PM
