6.0 firing order - TheDieselGarage.com
Thread Details Posted by pipeliner, this thread has received 3 replies and been viewed 36473 times.
post #1 of 4 (permalink) Old 02-16-2010, 12:01 AM Thread Starter
6.0 firing order
What is the firing order and how are the pistons numbered.
where is #4 piston located
pipeliner is offline
post #2 of 4 (permalink) Old 02-16-2010, 12:07 AM
Cylinder layout:
Facing the engine from the drivers seat (looking through the windshield):
Right side: 1 3 5 7 (Passenger Side)
Left side: 2 4 6 8 (Driver Side)
7 & 8 at the rear of the engine well (fire wall).
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline
The Following User Says Thank You to bismic For this addition to TDG:
pipeliner (02-16-2010)
post #3 of 4 (permalink) Old 02-16-2010, 12:24 AM
strokin6L's Avatar
but i don't know what the firing order is.
strokin6L is offline
post #4 of 4 (permalink) Old 02-16-2010, 12:29 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
Firing order is 1-2-7-3-4-5-6-8
2003 F250 "Pulling Truck"
hhrecovery is offline
The Following 2 Users Say Thank You to hhrecovery For this addition to TDG:
bismic (02-16-2010), pipeliner (02-16-2010)
Human Verification
Cyl. 2-3-5-8 firing late. SneakyPete 1994-2003 7.3L Power Stroke 8 05-25-2009 06:55 PM
cylinder not firing? 9512valve 5.9L Cummins 12 Valve (1994-1998.5) 21 04-20-2009 05:23 PM
Only firing on one side? 1996 StrokerKid 1994-2003 7.3L Power Stroke 11 12-31-2007 12:49 AM
firing order edkcmiller 6.5L Diesel Engine 1 07-24-2007 01:26 AM
