truck wont start hot - TheDieselGarage.com
Thread Details Posted by blizzardplower, this thread has received 11 replies and been viewed 11143 times.
post #1 of 12 (permalink) Old 03-08-2010, 10:26 PM Thread Starter
blizzardplower's Avatar
ok so far i have changed the icp cause it was throwing a code, branch tubes and the stc fitting a few months ago so i dont think any of those are my issue. when cranking the truck when cold it takes a few seconds for the oil pressure gauge on the dash to come up to where its supposed to be and when hot i can crank it over all day and it wont move but as long as i dont shut the truck off the oil gauge stays normal. im gonna pull the stc fitting to check if thats a problem but i dont think it is. could my lpop be going even though it only has 50k on it. thanks for the help i need this thing back up and running cause i have 3 people that want to buy the truck
'07 F350 dually 6spd manual trans, custom EGR delete, sct tune by the wonderful DJ, 4 pillar gauge pod with oil press., fuel press., boost and pyro, aFe intake with proguard 7 filter, arp headstuds, 29" hadley air horns, 15% tint all around with 10" eyebrow on windshield, 6" superlift lift kit, dual steering stabilizers, 5" mbrp straight pipe, 35"x12.5" cooper stt tires
blizzardplower is offline
post #2 of 12 (permalink) Old 03-08-2010, 10:46 PM
SLAPS President
teamroper60's Avatar
Images: 9
I'd check the o-rings in the oil logs first...
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #3 of 12 (permalink) Old 03-08-2010, 11:38 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
its the o-rings that go to the standpipes... just like Chuck said.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #4 of 12 (permalink) Old 03-09-2010, 07:32 AM
read this
New One-Piece High Pressure Oil Connector
Glossary
Since the redesign of the high pressure oil pump for 2005 and newer Power Stroke diesel engines the "snap-to-connect" or STC fitting used to connect the high pressure oil pump to the oil supply branch tube has been problematic. The two piece fittings have a tendency to flex causing wear on the seal and the locking ring resulting in leaks and occasionally the complete separation of the fitting. When a leak occurs at this fitting, the engine may be difficult to start or may not start at all. Depending on the severity of the leak the engine may stall, sometimes abruptly and without warning. See article 6.0L ICP System Leaks which describes high pressure oil system leaks and basic diagnostics.
A repair kit was developed containing a replacement fitting, connector and a bracket that supported the assembly preventing any movement of the branch tube and connector. See article HPOP Connector Bracket describing this kit in detail with photographs. To the best of our knowledge this kit is effective in preventing STC fitting failures and continues to be an approved repair. Some owners are installing this bracket as a preventative measure for piece of mind. We also recommend installing it if the pump is exposed during repairs however it is not covered under warranty unless the fitting fails. A new fitting shown below has been designed is a one piece connector most likely intended to address this issue for production engines. As of the date of this article, the fitting is available to International dealers and service departments but has not been released by Ford Motor Company as a service part however we have heard that this fitting will replace the STC bracket. The new connector is reported to be in production 4.5L and 6.0L Power Strokes for 2008 model year LCF trucks and Econoline along with the International VT-275 and the VT-365. The 6.0L Power Stroke diesel engine remains as an engine option for the 2008 Econoline.
The International Part Number is 1879930c91.
The fitting is installed in production engines starting from:
V8 engines: Engine ser# 431736 on 2/9/07.
V6 engines: Engine ser# 431705 on 2/8/07.
This article is only to provide information. It is hoped that it helps technicians in identifying possible causes and assist in the quick diagnosis of the identified concern. This is not intended to replace any official instructions, authorization or documentation of any Ford Motor Company Engineers, service manual, TSB, Service Message or recall.
Glossary
A new nuisance has become increasingly common and it's not a laughing matter. Just as the 7.3L Power Stroke had it's problems with o-rings both at the injectors and the external fittings, the 6.0L Power Stroke is developing it's own problematic oil control issues. To understand the significance of this article you need to understand that the HEUI (Hydraulic/Electronic Unit Injector) fuel injectors are a type of unit injectors that are actuated by high pressure engine oil. Without control of this pressure, these engines will not run.
The symptoms of a high pressure oil leak include:
Cranks / No start
Long crank to start
Stalls and wont restart
Wont restart hot but starts normally when cold
This is not a easy one to diagnose. The technician must first determine that there is a concern with the ICP system and typically this will show up as a continuous memory DTC. Monitoring the ICP parameter during cranking using a scan tool will verify low or no injection control pressure. The engine will not start until the PCM reads 500 psi from the ICP sensor and a low reading at this time will confirm a failure in the High Pressure Oil System.
Two important items to consider before looking for a leak:
A failure in the low pressure engine lube oil system will cause the ICP system to starve for oil. Verifying base engine oil pressure and repairing any concerns first is a must! The minimum engine oil pressure specifications are 82.7 kPa (12 psi) at 700 rpm, 165.5 kPa (24 psi) at 1,200 rpm and 310.3 kPa (45 psi) at 1,800 rpm with the engine at operating temperature. Low or no pressure could be caused by the oil pressure regulator valve, gerotor oil pump or an internal lube oil pressure leak.
If oil supply is not the cause, the ICP sensor, IPR valve, wiring and the PCM should also be checked for loose connections, damaged wiring and components and any applicable pinpoint tests should be performed to identify a failure in the control system.
The ICP Air Leak Test is performed by applying compressed air to the system using an adapter, closing the IPR valve and listening for an audible air leak. Isolating the leak can be difficult and time consuming because all of the related components are hidden inside the engine (6.0L). Photo #1 shows an F-Series truck with the ICP sensor removed and an air line connected directly to the right high pressure oil rail. Photo #2 shows the air connected at the high pressure oil pump because accessing the ICP sensor with the test fitting and an air hose is nearly impossible and very time consuming. Using an open tubed stethoscope to listen for air noise it will be necessary to remove the oil fill tube, the oil fill plug on the left head if equipped or the engine breather on the left valve cover. Minor air leaks at the pump shaft is considered normal. If the technician is lucky the leak will be found quickly otherwise access and removal of the high pressure pump and the oil rails will be necessary to inspect all of the seals for damage. This includes the HPOP discharge fittings, injector inlet o-rings, the crankcase to cylinder head feed tubes and plugs.
photo #1
photo #2
Common High Pressure Oil System Failures
Injector Inlet O-rings
photo #3
photo #4
Looking at the two photos of 6.0L injector oil inlets above, they may look similar but they are very different in their effect. The injector in Photo #3 is considered to be a full blown seal failure with the retaining ring, the backer ring and the o-ring all broken and pieces missing. This failure caused the engine to abruptly stall and it never restarted. This failure was easily located using the ICP air leak test. The injector in Photo #4 is an example of a failure in the beginning stages. This failure caused the engine not to start when it was hot due to the lower viscosity of the hot engine oil. The ICP air leak test was ineffective in detecting this leak due to it's size and the relative low pressure of the shop air. Unfortunately, both valve covers and oil rails had to be removed to inspect all 8 injector seals.
HPOP Discharge Fitting
photo #5
photo #6
The second common failure is the high pressure oil pump discharge quick disconnect fitting. Why this fitting is even there makes no sense. When this fitting fails to hold under pressure it separates damaging the female part of the coupling. Photo #5 shows the assembly attached to the pump. The fitting is separated and stuck in a cocked position as shown. Once apart the damage to the fitting is quite clear as you can see the fitting is elongated and the internal o-ring has come apart. This failure also resulted in the engine abruptly shutting off. The owner also reported long crank times for several days before the truck failed to restart.
This article is only to provide information and it is hoped that it may help technicians in diagnosing and repairing the concerns or failures as titled. This article is also intended to show what a technician does while performing this repair for the benefit of our visitors and vehicle owners. This is not intended to replace any official instructions, authorization or documentation of any Ford Motor Company published repairs or procedures. Due to safety risks, it is highly recommended that a trained and certified technician perform any diagnostics and repairs described.
Glossary
Cranks / No start
Long crank to start
photo #1
photo #2
photo #3
photo #4
photo #5
photo #6
bodacious diesel is offline
post #5 of 12 (permalink) Old 03-09-2010, 07:45 AM
http://www.forddoctorsdts.com/articl...icle-05-17.php
hear is the link it is to get a fitting i think it is a 12mm and adapter fitting to go to a male air hoes fitting and listien for leaks or you can put a 4,5oo lb gage on it and check the press. when hot you need at least 500 psi on the h.p.o.p. for the ficum to fier the injectors
post #6 of 12 (permalink) Old 03-09-2010, 07:50 AM
Wink
if you find that it is the injector o rings ford wont sell u them they want to sell the injector so if you need them i can sell u them for 12.00 each in sted of almost 300 for a injector jeremiah 3
Last edited by wastedwagesracing; 03-09-2010 at 04:43 PM. Reason: Removed Phone# non S/V
post #7 of 12 (permalink) Old 03-09-2010, 11:34 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
[quote=bodacious diesel;963060]if you find that it is the injector o rings ford wont sell u them they want to sell the injector so if you need them i can sell u them for 12.00 each in sted of almost 300 for a injector jeremiah
I buy injector orings from ford on a weekly basis... The msrp on them is 5.38 a piece and I bet EVERY dealer has them in stock.
post #8 of 12 (permalink) Old 03-09-2010, 04:36 PM Thread Starter
thanks for the tips. but will that give me the problem with the oil gauge not registering when warmed up
post #9 of 12 (permalink) Old 03-09-2010, 04:37 PM
05PSD's Avatar
Are you an authorized vendor for this site?
Also, my local dealer has them for 6.00 each.
05 F350 CC SB Lariat, Silverline exhaust, SCT tuned by Spartan,Inaccurate QZ Commander, deleted EGR, coolant filter, blown headgaskets
Last edited by wastedwagesracing; 03-09-2010 at 04:44 PM. Reason: Removed Non S/V phone number
05PSD is offline
post #10 of 12 (permalink) Old 03-09-2010, 06:14 PM Thread Starter
quick question the stand pipes should they be replaced anytime they are taken out ie. an injector being replaced cause i had to replace an injector on both sides and reused the old standpipes so they have been taken on and off 2 or 3 times
Human Verification
truck wont start. Wally1tm 5.9L Cummins 12 Valve (1994-1998.5) 4 01-05-2010 03:01 PM
Truck wont start! 7.3rambaler 1994-2003 7.3L Power Stroke 3 09-06-2009 04:43 PM
truck wont start MNFord 2003-2007 6.0L Power Stroke 10 02-20-2009 10:40 PM
Truck Wont Start weebz90 5.9L Cummins (1998.5-2002) 6 03-20-2007 05:25 PM
