P0700 - TheDieselGarage.com
Thread Details Posted by Trip, this thread has received 1 replies and been viewed 1839 times.
post #1 of 2 (permalink) Old 04-21-2010, 12:48 AM Thread Starter
Trip's Avatar
Angry P0700
Ok injector is in the truck, ypipe fixed wheel bearing and new tires done trans temp gauge sender done... now this I was cruising down a somewhat normal flat street @around 50Mph and 14-1500rpm and the truck downshifts to around2000 rpm I think that's odd no big deal still cruising make a left and accelerate once up to 55 or so stupid Engine lamp comes on I believe this light never goes out never it is the trucks way of telling me that it knows I am here. So I detour and grab my PC run AE and it says P0700 Transmission control system, DTC says internal transmission fault. No freeze frame or any thing where do I go from here any one deal with this should I stop driving it around. I need a transmission guru. I HATE ATUOMATICS
I don't understand them I don't want to just start throwing parts at it. I brought up one of the screens that allow you to watch what its doing and occasionally like every 3-5 seconds AE would say no read or something along those lines.
Thanks guys
03 F-250 Lariat 4X4 6.0L- NEW ID PROGRAMED FICM 105,000 (sitting on shelf while I figure out whats going on with the turd...furd) wheel berring 103,000 Dfuser coolant filter104,000, EGR plug104,000mi, y-pipe109,800mi,bootlegged 3.5" straight pipe110,000, rotors and pads on all 4 points 110,400mi, 35X12.50R17 Toyo M/T@ 111,300 ICP sensor 115,000
WALNUT (anti-ACORN) member#23
Trip is offline
post #2 of 2 (permalink) Old 04-21-2010, 07:41 AM Thread Starter
Trip's Avatar
Ok so I was reading thru some old post's that I had, in the past I have had a P0500 speed sensor A along with the P0700 where is this located?I did not throw a code this time for it but it has thrown in the past maybe this is where my problem is at.
and just to add to it I did back out of the Enhanced POWERTRAIN and went to the trans program on AE and there were no other codes.
Trip is offline
Human Verification
P0700 Code squeeky GM Transmissions 2 01-20-2009 10:20 AM
allison P0700, P0708 code's, need some help sparkchaser221 GM Transmissions 5 02-25-2008 04:24 PM
