P2509 Code - TheDieselGarage.com
Thread Details Posted by Dodgefarmer, this thread has received 4 replies and been viewed 10401 times.
post #1 of 5 (permalink) Old 11-28-2010, 05:01 PM Thread Starter
Dodgefarmer's Avatar
P2509 Code
Just had this code show up for the first time: P2509
Description for it is: "ecm/pcm Power Input Signal Intermittent"
Had the electric charging idiot light show up at the same time then went away with the next start on its own.
I have 93,000 miles with no mods since have to live with Calif Smog checks. I cleared the code with my scanner. Is there anything I should look for or ignore it for now and see if it shows up again later Or have dealer look at it before the 100,000 mile warantee is up? Prolly have to have the code return before dealer could check it out.
singles club # 198
Dodgefarmer is offline
post #2 of 5 (permalink) Old 11-29-2010, 04:48 AM
ADMIN/MAFIA
neeltburn's Avatar
When my neighbor had his 07.5 it would do this ( lighting bolt) but no cel. All he had to do was shut the truck off and restart. As far as the code i would call your dealer and see what they say, it will/should come back if thers is an issue.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
Dodgefarmer (11-29-2010)
post #3 of 5 (permalink) Old 11-29-2010, 04:43 PM Thread Starter
I think I found the problem. This morning had a P0562 code show up, low voltage, and temp was 30* this am. Checked batteries and only 12.2 volts and tester indicated bad batteries. When running the alternator was show 15+ volts. These are still the orginal batteries.
Off to NAPA to get new ones.
singles club # 198
post #4 of 5 (permalink) Old 11-29-2010, 05:19 PM
ADMIN/MAFIA
neeltburn's Avatar
I think i need to do the same thing, mine are still factory batteries.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 5 (permalink) Old 11-29-2010, 06:38 PM Thread Starter
New Batteries, cleared codes and all is good now
singles club # 198
Human Verification
code p2509 lilrebeljames 5.9L Cummins (2003-2007.5) 11 10-08-2010 05:59 PM
P2509 code 2blue11 5.9L Cummins (2003-2007.5) 2 09-08-2009 04:32 PM
Dtc p2509 Snowaholic 5.9L Cummins (2003-2007.5) 1 09-03-2009 01:14 AM
p2509 dalton06 5.9L Cummins (2003-2007.5) 0 04-10-2008 08:38 PM
P2509? ovruigo 5.9L Cummins (2003-2007.5) 0 11-23-2007 02:24 PM
