p2266 code - TheDieselGarage.com
Thread Details Posted by dodgefarmer2, this thread has received 12 replies and been viewed 3576 times.
post #1 of 13 (permalink) Old 11-01-2009, 11:56 PM Thread Starter
dodgefarmer2's Avatar
p2266 code
had a check eng light. read codes, shows a p2266 which means (water in fuel sensor circuit low) changed oil today, drained fuel filter in clean container and nothing but fuel. any ideas on what it means?
08 dodge 3500 dually, quad cab, inferno red,6.7, 4x4, 6sp auto, rhino lined bed, b&w gooseneck turnover ball,full length fiberglass running boards (color matching),reese hitch.
MEMBER THE DUALLY CLUB #75
MEMBER THE AMERICAN CLUB #41
10,055,000.00 points approximately
dodgefarmer2 is offline
post #2 of 13 (permalink) Old 11-02-2009, 12:39 AM
ADMIN/MAFIA
neeltburn's Avatar
check the plug on the bottom of the fuel filter. could be time to change fuel filter.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
dodgefarmer2 (11-02-2009)
post #3 of 13 (permalink) Old 11-02-2009, 12:56 AM Thread Starter
14995 miles, maybe its programmed in.
post #4 of 13 (permalink) Old 11-02-2009, 05:54 PM
I have 18,000 miles on mine and I haven't seen this code so I don't think it is a milage thing.
2010 big horn edition
6.7
singles club#202
carl76 is offline
The Following User Says Thank You to carl76 For this addition to TDG:
dodgefarmer2 (11-03-2009)
post #5 of 13 (permalink) Old 11-03-2009, 01:16 AM
ADMIN/MAFIA
neeltburn's Avatar
You have 18k on one fuel filter...
I wouldn't expect it to be mileage related more fuel...if you get really good clean fuel sure it would go longer but I always change my fuel filter every 10-15k..
Though if I got the water in fuel message I would prolly go ahead and change the filter as well.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #6 of 13 (permalink) Old 11-03-2009, 01:34 AM
Dodgefarmer's Avatar
I have on my 07 6.7 cummins 45,000 miles on the current filter, although its prefiltered at my pumps before being pumped. On some equipment I can get 2000 hrs on a filter and go 2+ yrs. when the manual says change fuel filter every 3-600 hrs. Heck I have John Deere stationary pump motors that have gone ~10,000 hrs. Then again I have a prefilter at the tank and they are 3000 gallon tanks at the pump and get filled at least twice per year at each pump.
Life of the filter depends on clean the fuel is,minimizing the moisture that gets into the fuel.
singles club # 198
Dodgefarmer is offline
post #7 of 13 (permalink) Old 11-03-2009, 01:35 PM
since we are on the subject, I was wondering how hard is the filter to change and how does it come off? I open the drain on the bottom every once in a while to check for water but I can't say that I have ever seen any and the water light has never came on but I still check it. I have been thinking of changing the filter for good measure but I didn't quite figure out how it came off.
6.7
singles club#202
carl76 is offline
post #8 of 13 (permalink) Old 11-03-2009, 03:12 PM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
They are a BIOTCH!!!!! to change compared to a 5.9 hard not to get fuel everywhere or maybe i ws really drunk the other night when i changed oil and filters they have new housings out now at the dodge dealerships that you can just buy replaceable filters instead of buying whole housings...but that little burger is $7? and the replacement filters are still kinda high at $35
Military Quote Of The Year
SOOTBANDIT is offline
post #9 of 13 (permalink) Old 11-04-2009, 12:52 AM Thread Starter
code has disappeared for now. thinking of changing mine at 20,000 at the next oil change. it looks like it could be a pain in the @$$
post #10 of 13 (permalink) Old 11-04-2009, 04:58 AM
ADMIN/MAFIA
neeltburn's Avatar
This may help for the fuel filter change..
Fuel Filter Change?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
dodgefarmer2 (11-04-2009)
Human Verification
Can I Put J-Code Exhaust Manifolds On a C-Code Engine JLanzino 6.2L Diesel Engine 6 10-08-2009 03:29 AM
code kc04 6.7L Cummins (2007.5-2011) 3 04-19-2009 04:38 PM
P1689 ERROR CODE - Cause of code Found! Mopar1973Man 5.9L Cummins (1998.5-2002) 6 02-02-2009 03:36 PM
what does this code mean fender Duramax 2001-2004 (LB7) 7 06-03-2006 06:33 PM
sct and kam code Adam 2003-2007 6.0 Tuner Forum 13 06-02-2006 09:22 PM
