855 big cam with stc - TheDieselGarage.com
Thread Details Posted by DirtyDee, this thread has received 0 replies and been viewed 140 times.
post #1 of 1 (permalink) Old 11-16-2016, 12:06 AM Thread Starter
Angry 855 big cam with stc
Looking for help with 855 cummins with stc. Smokes like a mother all the time. Repaired all oil leaks in the stc system and then set the overhead and still smoked. I teed in a gauge between stc valve and oil manifold and had 15 psi which o think is the minimum pressure. Felt manifold on each cylinder and one was cold so i sent all injectors to be rebuilt by a trusted shop. Put all injectors back in and problem was the same but instead of one cold.cylinder there was 3. I have a hard time believing it is the injectors because every time you start it up you have different cold cylinders. I replaced the stc valve and still the same problem. Removed turbo and exhaust manifold and one started smoking and then quit and them 2 started smoking. Possible bad cam lobes?????Is 15 psi enough oil psi to run stc system???? Truck is over fueling and i cant figure out why. Any help would be greatly appreciated.
DirtyDee is offline
Tags
855, bigcam, cummins, stc, whitesmoke
Human Verification
big cam 855 head vent holes 5.7diesel Medium and Heavy Duty 7 02-12-2014 06:06 AM
Cam Replacement on Big Cam Cummins LOG HAULER Medium and Heavy Duty 3 05-18-2013 04:00 AM
Small Cam/Big cam Cummins LOG HAULER Medium and Heavy Duty 17 04-25-2013 04:33 AM
big cam 444 converted to normal big cam? cdwood388 Medium and Heavy Duty 2 01-02-2013 07:48 AM
00 fuel button big cam 855 Big Jake Medium and Heavy Duty 6 10-30-2011 08:54 PM
