1996 hard start, rough idle, smoking - TheDieselGarage.com
Thread Details Posted by Dennis L, this thread has received 1 replies and been viewed 2067 times.
post #1 of 2 (permalink) Old 06-07-2012, 01:26 AM Thread Starter
I had to pull my powerstroke out to reinstall the oil plug on the inside of the timing cover. I figured while I was there & since the engine was on the floor, I would replace the injector o'rings. After I installed the engine, it took a very long time to start. It had a rough idle & smoked like a freight train. It was suggested that I take it for a drive. I ran it about 50 miles & it still would not idle smoothly & smoked worse since it was hot. Smokes at idle or underway, doesn't matter. Before I replaced the seals in the injectors, the truck ran really well, no smoke. One thing I did notice was that when I showered down on it, one cylinder started really rattling, so loudly that I backed out of it each time. Never got any better. I convinced myself that I had damaged an o'ring, but I cannot find a bad one after I removed all eight. I might add here that the thought struck me to pull the fuel filter first & check for oil, (after I pulled the injectors) but I was frustrated. The fuel filter showed no signs of oil. This is my first powerstroke, so this has been on-the-job training. I need this thing so I can trailer some tractors to an antique pull Saturday, so please help! Thanks!
Dennis L is offline
post #2 of 2 (permalink) Old 06-09-2012, 03:41 PM
BODEY
huntem's Avatar
Did you knock a injector cup loose?
2000 F-350 7.3L
huntem is offline
Human Verification
Smoking and hard start after injector change dburress 1994-2003 7.3L Power Stroke 13 09-11-2010 01:47 PM
Rough idle after hard acceleration???????? jktcummins 5.9L Cummins (1998.5-2002) 9 11-13-2007 04:09 PM
hard starting rough idle blue smoke 87_f250 7.3L and 6.9 IDI (Pre 1994) 11 01-21-2007 02:02 PM
Hard start and rough idle Diesel_Head 2003-2007 6.0L Power Stroke 12 09-27-2006 02:57 AM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 07:32 AM
