2001 7.3 excursion wont turn on help - TheDieselGarage.com
Thread Details Posted by 05f250305, this thread has received 10 replies and been viewed 810 times.
post #1 of 11 (permalink) Old 04-25-2017, 11:35 PM Thread Starter
ever since i owned this truck i replace all injector cup(one was leaking and did all the extra parts at the same time) and injector o ring all glow plugs and harness it was working great with no issues, i decided to change the icp and ipr and the positive battery wiring harness because the truck always gave me a problem in the morning starting. after i change both sensor, the truck was on for 1 hour with no problems i took it for a test drive and it turn off in the corner of my house and it wont turn on again it cranks but wont turn on. i replace the new sensors with old sensors from a 1997 7.3 that was running and still the same thing i place the new ipr in the 1997 and the truck turn on and it worksfine not sure what to do at this point and im not trying to waste money just buying new parts can someone help me the truck has 172000 miles
05f250305 is offline
post #2 of 11 (permalink) Old 04-28-2017, 04:17 PM
w9l
w9l's Avatar
Does your oil pressure gauge rise off the peg when cranking? If not check your oil. If oil level is ok, take the plug out of top of hpop (takes an allen wrench) and check oil level there. Should be less than an inch from top. If not, add oil and try to start. If it starts then we can discuss possible causes.
Also, when cranking, does tach needle bounce? If not check to make sure cps is plugged in and?or swap out cps with known good.
Just me
w9l is offline
post #3 of 11 (permalink) Old 05-01-2017, 12:26 AM
Stuck in Commiefornia...
IdahoF350's Avatar
Diagnostic info is a must on these trucks. Since it sounds like you have another truck that can be used for parts swapping purposes, after you check the oil levels, try swapping the Cam Position Sensor (CPS) it's a common issue, and without cam and crank position info, the computer will not fire the injectors.
2000 Excursion XLT 4x4
IdahoF350 is offline
post #4 of 11 (permalink) Old 05-05-2017, 05:36 PM Thread Starter
yes my oil pressure gauge does rise when cranking. oil level is fine in both areas. i also replace the cps sensor thinking it was the problem and nothing
replace with a new oem cps it was only $20
they told me it could be the idm but dont want to waste $200 on a rebuilt unit. will the 1997 7.3 idm and pcm work on a 2001 7.3
post #5 of 11 (permalink) Old 05-08-2017, 01:58 PM Thread Starter
had the code p063 p1316 p1280 p1670
post #6 of 11 (permalink) Old 05-08-2017, 01:59 PM Thread Starter
have code p0683 p1316 p1280 p1670
post #7 of 11 (permalink) Old 05-11-2017, 01:14 PM Thread Starter
any help
post #8 of 11 (permalink) Old 05-12-2017, 10:06 AM
Jasong's Avatar
I'm no expert, but I believe they are the same part.
Jasong is offline
post #9 of 11 (permalink) Old 05-18-2017, 12:44 PM
w9l
w9l's Avatar
683=glow plug control module, check connections- to my knowledge they seldom go bad?
1316=idm issue. check and double check valve cover harness, both plugs, both sides?
1280=icp out of range low.
1670=communication error.
With this combo of codes I am inclined to think you are on the right track with idm diagnosis. I am no pro. I just own 2 of these and one since new. I agree with Jasong, I think idm is the same. double check by looking up with Rockauto and a couple other places to verify?
Just me
w9l is offline
post #10 of 11 (permalink) Old 05-28-2017, 01:24 AM Thread Starter
it was the idm change it and is working but now i have a few more codes
KOEO injector buzz test
p1272
p1274
p1276
p1278
p1294
is running rough cold only and fine in regular temp
Human Verification
A/C compressor wont turn off ranger518 2003-2007 6.0L Power Stroke 4 06-12-2012 10:41 PM
steering wont turn 05f250305 2003-2007 6.0L Power Stroke 4 03-06-2012 04:14 AM
Engine wont turn off???? cumminssoon 5.9L Cummins 12 Valve (1994-1998.5) 2 03-23-2009 01:26 AM
truck wont turn!! 2008TT450 Duramax 2001-2004 (LB7) 9 12-29-2007 04:16 AM
Headlight wont turn off tunaluvar 1994-2003 7.3L Power Stroke 4 03-02-2006 07:22 PM
