max boost stock 7.3l auto - TheDieselGarage.com
Thread Details Posted by 86 1 tonhauler, this thread has received 14 replies and been viewed 8252 times.
post #1 of 15 (permalink) Old 04-03-2009, 02:22 AM Thread Starter
TDG MAFIA MEMBER #72
86 1 tonhauler's Avatar
Send a message via Yahoo to 86 1 tonhauler
what is the stock max boost you would see from a 2000 7.3l with a auto trans
and intake and exhaust , spikes to 20 then backs down 15 with it wide open
1986 f-350 6.9 dually str8 piped ,maxed out injection pump ,bucket seats, diamond plate flat bed,propane injection, on board aircompressor, train horns,goose neck plate, future mod , custom built turbo kit with intercooler and dual 4" miter cut stacks TDG DUALLY CLUB #5
RIDIN DIRTY #44
01 chevy 2500 HD 4x4 duramax
anybody got any used 4" miter cut stack laying around? pm me if ya do
quote: BARRY1ME: BTW I love your sig about engineers....but it should be changed to, if the engineers believe it isnt broke it doesnt have enough content removed from it. And thats the truth! (FYI I am engineer and work for Ford lol) At Ford the goal is to make the part barely good enough to passing DV (developmental validation) testing....If it passes way beyond the test then the part was overengineered, and content needs to be removed to reduce cost.
I CANT KEEP UP!!! HELP!!!
86 1 tonhauler is offline
post #2 of 15 (permalink) Old 04-03-2009, 02:35 AM
pontiacross's Avatar
Thats probably not to far off.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 15 (permalink) Old 04-03-2009, 02:40 AM
Holding 16-18 psi consistently is normal for a bone stock truck. Max I ever saw in stock form was 18 psi.
Pocket is offline
post #4 of 15 (permalink) Old 04-03-2009, 03:43 AM Thread Starter
cool , trucks got some miles on it 235k
RIDIN DIRTY #44
post #5 of 15 (permalink) Old 04-04-2009, 06:14 PM
7.3rambaler's Avatar
not stock but i've hit 28 with the ts
2000 F-250 7.3L. Ext Cab. Short Box.
Dp Tuner 80 eco-tune
Fully Built Tranny with Triple Disk Converter
AFE stage 2, 4in from turbo back stright pipe, foil Delete, X-Wheel Gauges-tranny-pryo-boost
7.3rambaler is offline
post #6 of 15 (permalink) Old 04-06-2009, 04:21 PM
ccp
THE MASTER OF DISASTER
ccp's Avatar
Send a message via AIM to ccp
i can get 40 on stock turbo with jodys tunes but im waiting for the turbo to go boom it doesnt hit 40 til about 90mph with the pedal to the floor the last shift shoots the boost from about 34 to 40.
99.5 F-250 7.3 4X4 reg cab.
custom intake
dp tuner
suncoast/DTT Frankentrans
and a whole bunch of other crap i dont really need.
www.cabincreekpaintball.com
ccp is offline
post #7 of 15 (permalink) Old 04-06-2009, 05:56 PM
MAFIA MEMBER 106
camojeeper's Avatar
i get 40 pounds
STEVE TDG MAFIA#106
76 CJ-7 B/B FUEL INJECTED AMC 401cid V-8, T-18, D 20 transfer case with 5.38's in the D44's full family cage,ARB air locker rear, lock right front, 37"goodyears steve@magicsmokeperformance.com
camojeeper is offline
post #8 of 15 (permalink) Old 04-06-2009, 07:29 PM
Mod Friendly Title
Zaairman's Avatar
I thought anything over 25 would kill a stock turbo fast?
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #9 of 15 (permalink) Old 04-06-2009, 08:32 PM
MAFIA MEMBER 106
camojeeper's Avatar
so far mine is hangen in there but MY NEW van turbo will be on on friday thanks PRT
STEVE TDG MAFIA#106
post #10 of 15 (permalink) Old 04-06-2009, 11:13 PM
TDG Mafia Member # 37
01blkf250's Avatar
I killed my stock one pretty quick hitting 37lbs. of boost once in a while and hitting 33lbs. quite frequently. Gene
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
Human Verification
stock boost ? need help jford93 2003-2007 6.0L Power Stroke 18 03-13-2009 02:31 AM
How much can stock auto take? Skyhigh4by 5.9L Cummins (2003-2007.5) 4 01-10-2008 02:27 AM
Smarty q's and stock auto trans stubbs031 5.9L Cummins (2003-2007.5) 5 10-05-2007 07:55 PM
Bullydog a danger for a stock auto? Teelo 5.9L Cummins (2003-2007.5) 21 04-23-2007 01:49 AM
Auto Meter Lunar Pyro/Boost/A-pillar Dockboy Whats Been Sold 11 02-14-2006 03:06 AM
