Up-Pipe Replacement - TheDieselGarage.com
Thread Details Posted by edge186, this thread has received 6 replies and been viewed 3308 times.
post #1 of 7 (permalink) Old 11-17-2009, 06:15 AM Thread Starter
edge186's Avatar
Up-Pipe Replacement
I am in need of a new set of up-pipes. when i can afford it im going to order the ceramic coated ones from DI.
http://67.19.132.3/dieselinnovations...ts&product=270
I talked to a Ford mechanic to see what all i would need to do to replace them and he told me the easiest way is to pull the transmission. Somehow this seems overkill to me but maybe im wrong.
To me it looks like if i pull the downpipe off and the intake off the turbo i could probably get them off.
Any tips on doing this?
2001 Ford F-250 Superduty PSD
CC, SB, Auto
Power Hungry Performance
ATS Straight Pipe
ATS Ported Compressor Housing
AFE Stg II Intake
CCV Mod
Foil Delete
6.0 Trans Cooler
B&W Hitch
edge186 is offline
post #2 of 7 (permalink) Old 11-17-2009, 01:15 PM
plainredtruck's Avatar
Images: 11
The Ford mechanic probably is correct, but he has access to a lift and all sorts of stuff that make it easy.
And, he gets paid to drop the transmission to replace the up-pipes.
I'll dig up a write-up and let you decide which method you prefer.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 7 (permalink) Old 11-17-2009, 01:23 PM
Here's how I did mine: http://www.guzzle7pt3.com/upp.php
Pocket is offline
The Following User Says Thank You to Pocket For this addition to TDG:
TxFxL (11-19-2009)
post #4 of 7 (permalink) Old 11-17-2009, 01:37 PM
Images: 11
That's what I was going to link to as well.
I did a write-up that was not as thorough as that, but it was lost in the hack last year.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #5 of 7 (permalink) Old 11-17-2009, 04:19 PM Thread Starter
edge186's Avatar
okay thanks guys. what do you recommend as far as pipes? should i go with the coated ones in my link or are coated ones not necessary?
CC, SB, Auto
ATS Straight Pipe
AFE Stg II Intake
CCV Mod
Foil Delete
6.0 Trans Cooler
B&W Hitch
edge186 is offline
post #6 of 7 (permalink) Old 11-17-2009, 05:22 PM
Images: 11
Those are nice up-pipes, but the coating isn't necessary.
If you plan to build a true performance truck, then maybe, just maybe you want to spend the pocket change on ceramic coating . . .
I know where there's a set of Stainless bellowed pipes for sales for $350. I'll PM you the link.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
The Following User Says Thank You to plainredtruck For this addition to TDG:
edge186 (11-17-2009)
post #7 of 7 (permalink) Old 11-19-2009, 06:22 PM Thread Starter
edge186's Avatar
well... new DI Stainless Up Pipes are on the way.
CC, SB, Auto
ATS Straight Pipe
AFE Stg II Intake
CCV Mod
Foil Delete
6.0 Trans Cooler
B&W Hitch
edge186 is offline
Human Verification
best replacement down pipe needed asap trucks2u 2008-2010 6.4L Engine Tuner Forum 15 10-22-2009 02:24 PM
Duramax Replacement Down Pipe - Coming Son Jesse@MBRP Supporting Vendors Forum 2 08-18-2009 05:07 PM
Van Air Intake Pipe Replacement ripmf666 GM Spec Info 0 12-28-2008 11:57 AM
Up-pipe Donut Replacement Early 99 Got Diesel 1994-2003 7.3L Power Stroke 27 10-28-2007 05:06 PM
OBS 7.3L Up-Pipe gasket replacement imported_BigGreen 1994-2003 7.3L Power Stroke 6 05-12-2006 01:37 AM
