315's on a F250 - TheDieselGarage.com
Thread Details Posted by imported_JDeere5105, this thread has received 13 replies and been viewed 1805 times.
post #1 of 14 (permalink) Old 08-14-2006, 03:26 PM Thread Starter
315's on a F250
How much lift is needed on an 05 F250 to clear 315's or even 305's? Pics would be good also.:
Thanks
Jason
2005 F250 PSD 4x4 TS Ext cab LWB
Upfitter switches added and high idle mod..Thanks to these awesome forums.
SCT from Innovative
MBRP Turbo back....Missing Kitty....If found do not return
Outlook monitor
Zoodad mod
ARP Headstuds
Coolant Filter
imported_JDeere5105 is offline
post #2 of 14 (permalink) Old 08-14-2006, 03:41 PM
TDG MAFIA MEMBER #44
Send a message via AIM to 6point6 Send a message via MSN to 6point6
You can clear 305's stock with no problem. I know you can fit 315's and don't think they'll scrub but with a leveling kit they surely wouldn't scrub. I think a 315 is roughly like 34.5 inches tall while the stock 20's that come on some 06's are 34.1 inches tall. That meaning you should be fine on a stock rim. Hope this helps.
2006 CC FX4 PSD 6.0 (GONE)
2005 LLY Duramax CC SB 4x4 - PPE Hot +2 ET on Level 8, MBRP 4" Straight piped Exhaust, PPE Intake, 315 Cooper STT's on stockers!
6point6 is offline
post #3 of 14 (permalink) Old 08-14-2006, 03:48 PM Thread Starter
Thanks for the reply.
SCT from Innovative
Outlook monitor
Zoodad mod
ARP Headstuds
Coolant Filter
post #4 of 14 (permalink) Old 08-14-2006, 05:33 PM
No problem! Glad I could help!
6point6 is offline
post #5 of 14 (permalink) Old 08-14-2006, 07:41 PM
Rene G's Avatar
However, 35's on a stock truck will rub when going lock to lock, or when going over rough roads... or so I've been told. I run 33x12.50R18 on my stock truck.
09 F-350 FX4 lux package, everything but sunroof
Suncoast rebuilt trans. and converter
Line-X box liner and rocker panels
4-lightforce lights on KC light bar
OUO Traction 5"traction blocks
Icon adjustable track bar
Air bags and compressor
Icon 2.5" Leveling kit
Marathon sled deck
Flo-pro exhaust
S&B intake
Waiting for time to install
Dirty Diesel cold side I/C pipe
CANADIAN CLUB MEMBER #15
SINGLES CLUB MEMBER #227
spartan tuned courtesy of www.dirtydieselcustoms.com
Rene G is offline
post #6 of 14 (permalink) Old 08-14-2006, 08:28 PM
Yeah but a 315 isn't a true 35....It equates to 34.5 according to BF Goodrich and I know all the tire calculators that I've put a 275/60/20 came back with 34.1 inches so I don't think half an inch will make much difference especially on a stock rim. Now with aftermarket rims with different offsets and backspacing it's possible you would have a problem but I know plenty of people with stock 17's running BFG AT 315's and don't have a problem
6point6 is offline
post #7 of 14 (permalink) Old 08-15-2006, 04:42 PM
TDG Mafia Member #25
adrianspeeder's Avatar
How bout on an 02 with the leaf springs up front?
adrianspeeder is offline
post #8 of 14 (permalink) Old 08-15-2006, 05:39 PM
You would need a leveling kit or 2" blocks if running with a stock rim or an aftermarket with a close backspacing.
6point6 is offline
post #9 of 14 (permalink) Old 08-16-2006, 01:43 AM
It's not just the diameter, but the width will affect rub also as it moves the tires edge further from the center of steering axis, and therefore will have a greater chance of rubbing.
2004 F-350, 4x4, SC, LB, 6.0PSD, 6spd
Changed a few things. More than some, less than others
Betaracer is offline
post #10 of 14 (permalink) Old 08-16-2006, 12:27 PM
Cool, so whats the biggest numbers I can run without lift blocks. A little rubbing at full lock doesn't bother me. (Got 33x12.5s stuffed under the 84)
Adrianspeeder
Human Verification
