Installing a cooler in with my power steering/hydro boost - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 2 replies and been viewed 1041 times.
post #1 of 3 (permalink) Old 03-28-2010, 02:20 AM Thread Starter
I picked up what I think could be the perfect cooler for my power steering and hydro boost system. But, I have a couple of questions before I tear into it. I know Ford had the idea of running all that extra cooling line across the cross member to help cooling. So if I install that cooler, will I still require all that extra line? Also, where should the cooler be installed in the lines? At what point in the circulation process would be the best place to hack in and install the cooler?
post #2 of 3 (permalink) Old 03-28-2010, 04:28 AM
Needs more mod money !
njneer1's Avatar
It has to go in the return line......and where it will get the most air......you did not describe the cooler.....I assume it is an air to oil type.
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, EGT/Boost/ Trans temp
njneer1 is offline
post #3 of 3 (permalink) Old 03-28-2010, 01:56 PM Thread Starter
It is. I will try and get a photograph up as well. I would love for some one to identify who made this thing and maybe what vehicle it came out of.
Human Verification
hydro-boost??? snowman_w900 5.9L Cummins (1998.5-2002) 1 03-23-2010 05:40 PM
Hydro Steering assist bigastrk Supporting Vendors Forum 1 01-29-2010 02:08 AM
EGR cooler delete + new oil cooler= no boost barnbridge 2003-2007 6.0L Power Stroke 4 11-06-2009 04:28 AM
my epic tail of installing DFusers egr cooler delete kit harleystroker 2003-2007 6.0L Power Stroke 42 10-27-2009 01:53 AM
Installing power mirrors on an XL? Fantom3993 General Ford Truck and Excursion 2 07-24-2007 05:58 AM
