6.0 Intercooler Install - TheDieselGarage.com
Thread Details Posted by 4cstr, this thread has received 18 replies and been viewed 13342 times.
post #1 of 19 (permalink) Old 12-16-2005, 09:30 AM Thread Starter
4cstr
With the EXPERT help of the guys from the Western New York Powerstroke Club, Thanks Gar, Jim, Jeff and Kory, I just finished the 6.0 intercooler.
The new intercooler is 31% bigger.
Original 30x18x2
6.0 30x21x2.25
It was easier than I thought, much of the time was on the fly engineering. I have not fired it up yet so I have a few concerns I will address.
INSTALLATION
Either drain radiator or drain enough to remove upper radiator hose
Remove over flow tank on top of the radiator
remove all radiator and AC condensor mounts but do not remove either
Remove upper radiator hose.
Remove bolts holding fan shroud
I have a stick so you might have to move the tranny cooler on an auto??
Remove 2 bolts holding Intercooler and hoses connecting to pipes
Tilt back the radiator as far as possible and pull the intercooler out. This will take some manuevering to get it clear of the AC lines(removing the condensor mounts allows moving of the lines) but it will come out. Better to have 2 people one at each end.
The new intercooler is 1/4 inch thicker so you will have to get the fan shroud in just the right spot and the radiator a little farther back to get the new one in place. again 2 people for this. Bolts right up to the original mounts.
NOW THE FUN PART
The intercooler tubes do not fit!
This took some time but our fearless leader Gar Hanson figured it out.
The inlet is smaller on the new intercooler, same size 3" as the intercooler tubes. The outlet is the same size as the original.
The inlet and outlet are also an inch shorter so we needed to fill this gap and figure out the size problem.
The solution was simple. you need 2 napa intercooler hoses Part number 1701 and 1740 and 2 extra clamps
Cut off 2.5 inches of the oultet pipe near the intercooler, passenger side of the truck, save this short piece. attactch the 1701 hose on the shortened intercooler pipe, attatch the 2.5 inch piece you cut off to connect the new hose from NAPA to the stock blue hose. This blue hose fits on the new intercooler. you use the new NAPA hose to add 1/2 to 1 inch of length. Cutting the pipe and reconnecting it with a 1/2 inch or so gap gives you the extra lenght you need.
On the other side the NAPA hose 1740 adds the extra length needed.
Thighten it all up! put the other parts back in place!
WFTREE
post #2 of 19 (permalink) Old 05-18-2006, 07:44 PM
adambomb's Avatar
Question
can this mod be done to an Early 99 the same way as described above???
adambomb is offline
post #3 of 19 (permalink) Old 05-24-2006, 07:04 AM
TDG MAFIA MEMBER #85
onebadf150's Avatar
Wait I don't understand you had to cut the hot side intercooler pipe b/c it was to long, doesn't make sense I haven't heard of this problem yet and I've read alot of post concerning this install, I not saying its not a problem and I'll watch for this when installing mine, thanks for the write up and part #'s :Thumbup:
Nick
onebadf150 is offline
post #4 of 19 (permalink) Old 05-24-2006, 01:30 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
Take some pics when you do yours so that it will be more helpful...
2003 F250 "Pulling Truck"
hhrecovery is offline
post #5 of 19 (permalink) Old 10-23-2006, 05:59 AM
NativeCustomBaggers
Intercooler for my 97?
[QUOTE=4cstr]With the EXPERT help of the guys from the Western New York Powerstroke Club, Thanks Gar, Jim, Jeff and Kory, I just finished the 6.0 intercooler.
I heard I can adapt a 6.0 intercooler to my 97 powerstoke. Can this be done? If so, which is the best year intercooler to use and can I use all the tubing or does it have to be custom made? If I can't adapt one, which is the best brand to use for my 97? Thanks. Paul.
CustomBaggers is offline
post #6 of 19 (permalink) Old 10-23-2006, 04:29 PM
CSIPSD's Avatar
Yes you can. Pm me and I will give you a few sites to look at for a IC install
CSIPSD is offline
post #7 of 19 (permalink) Old 11-07-2006, 03:03 AM
CSIPSD's Avatar
I did the install this weekend, here are a few pic's I took...
http://www.thedieselgarage.com/galle...c=9&userid=932
Name:	6.0 installed.JPG
ID:	7209   Click image for larger version
Name:	Condenser brackets going back in.JPG
ID:	7210   Click image for larger version
Name:	drop bracket for Tranny and PS coolers.JPG
ID:	7211   Click image for larger version
ID:	7212   Click image for larger version
Name:	IC pipes removed.JPG
ID:	7214   Click image for larger version
Name:	lowering bracket.JPG
ID:	7215   Click image for larger version
Name:	new AC condenser.JPG
ID:	7216   Click image for larger version
Name:	removeing core support.JPG
ID:	7217   Click image for larger version
Name:	rubber valance removed.JPG
CSIPSD is offline
post #8 of 19 (permalink) Old 11-07-2006, 03:05 AM
CSIPSD's Avatar
A few more...
Name:	size compare.JPG
ID:	7219   Click image for larger version
Name:	top view size.JPG
CSIPSD is offline
post #9 of 19 (permalink) Old 12-04-2006, 08:52 PM
INteresting.
southernlx is offline
post #10 of 19 (permalink) Old 12-23-2006, 06:52 PM
Can 6.0L intercoolers be installed in my 1997 F-250? If so plaese can anyone get me some information? And I was also curious of whether you can put 5" downpipes on first generation torbo powerstrokes?
BryanC7.3 is offline
Human Verification
