How to turn up fuel on 6.9/7.3 IDI - Page 3 - TheDieselGarage.com
Thread Details Posted by 4cstr, this thread has received 22 replies and been viewed 83309 times.
post #21 of 23 (permalink) Old 01-30-2008, 11:45 PM
heres a tip, turning the screw up inside the plate is only step 1, there is another screw on the pump to get it to smoke, that screw everyone tells you to turn up only affects how much fuel you get at peak torque and under a load, but going less than 1/4 turn will help for step 2. to get to the 2nd screw, go to the injector outlet lines where they are in a circle, in the center of that there is a fuel line going in to the pump, unscrew the line, and there is another allen screw inside there, turn that one in clockwise 1/8 to 3/16 of a turn, if you want go no more than 1/4 turn. It will smoke good now.
t_chapps is offline
post #22 of 23 (permalink) Old 03-20-2008, 09:42 AM
dagon dagon!
Originally Posted by peejcj8
I have a 94 F250 7.3 that produces alot of fuel smell in the exhaust along with smoke. It does this continually.
Would adjusting down the fuel amount on the Pump be a posible solution, or should I look elsewhere first?
What should I do to fix this?
Please help, my Girlfriend will not ride in my smokey truck.
that sounds more like a personal problem than a truck problem. :evil:
97 Ram 3500 2wd dually 12v ff #0 fuel plate, upgraded compressor wheel, nv 4500 rock crusher, 4.10 rear gooseneck & 5th wheel hitch... also has access to underbed repo wheel lift
94 Chevy silverado Blazer 4X4, 350, 700r4, sound system from hell... still drive the dodge mostly
US navy construction & tactical vehicle fleet -Seabee and proud of it!
Navy_Seabee_CM is offline
post #23 of 23 (permalink) Old 09-12-2009, 08:53 PM
Super Moderator
nevrenufhp's Avatar
Has anyone done this? Should we add it to this article?
Dale
or, 08 VW R32.
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
Human Verification
