front sump to rear sump - TheDieselGarage.com
Thread Details Posted by 04lariatfx4crewcab, this thread has received 20 replies and been viewed 7364 times.
post #1 of 21 (permalink) Old 03-01-2011, 07:34 PM Thread Starter
04lariatfx4crewcab's Avatar
I was looking at some pictures today and I noticed the 12v from a dodge pickup is a rear sump oil pan but the motor I have is a front sump what will it take to change mine to a rear sump? is it just the oil pan and pickup tube or is there more to it?
Sorry for all the questions but I just want to get this figured out before I get too far along.
Thanks
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #2 of 21 (permalink) Old 03-01-2011, 07:43 PM
Send a message via AIM to slow00si
should just be the pan and pickup tube as when i had my pan off there is no baffle or anything and also might have to change dipsticks and location depending on where yours is now should be on the d/s towards the back to run the rear sump
02 f250 ccsb lariat 12v and nv4500 swap in the works
slow00si is offline
The Following User Says Thank You to slow00si For this addition to TDG:
04lariatfx4crewcab (03-01-2011)
post #3 of 21 (permalink) Old 03-01-2011, 08:49 PM Thread Starter
I need to look at my dip stick. it currently is toward the front right under the power steering pump. guess I need to cap off the old and find a new location.
Jakob
post #4 of 21 (permalink) Old 03-02-2011, 01:25 AM
yea i glanced at my block earlier and it has a spot in the front that looked to have a freeze plug in it so yours will probably have a spot towards the back under the starter with a plug that needs to be knocked out for the new location then plug the front one
slow00si is offline
04lariatfx4crewcab (03-02-2011)
post #5 of 21 (permalink) Old 03-02-2011, 02:22 PM Thread Starter
Thanks, My motor is set up funny the starter is on the pass. side. But I think I know what you are talking about.
Jakob
post #6 of 21 (permalink) Old 03-03-2011, 06:02 PM Thread Starter
I was looking at it some last night, it looks like I can relocate my dipstick and simply rotate the oil pan 180* but I can not find anything on the oil pick-up, can I just spin that?
Jakob
post #7 of 21 (permalink) Old 03-03-2011, 08:01 PM
no the pickup on the truck engine starts from the front on the oil pump then runs along the front of the pan then all the way down the driverside of the pan then drops down for the pickup part and i think the pan is symmetrical so i doubt it will spin around and bolt up
slow00si is offline
post #8 of 21 (permalink) Old 03-03-2011, 08:57 PM Thread Starter
I think I read somewhere that you can rotate the pan but it is bigger than the dodge pan so it might not fit. Dang I should have bought a truck motor, but this was priced right.
Jakob
post #9 of 21 (permalink) Old 03-04-2011, 03:14 AM
Pappy
MOPSD250's Avatar
Ya you cant spin the pan if it was a front sump. You gonna have to get a rear sump off a 12/24V and oil pickup to. I got a sweet deal on a 24V with a front sump. Had a buddy who blew his 12V up got his oil pan and pick up. Kinda off subject with the 24V stuff but same concept
2003 F250 Super Duty SC 8' Bed 12V CONVERSION DONE!!!!
24V P-pump Conversion Soon
MOPSD250 is offline
The Following User Says Thank You to MOPSD250 For this addition to TDG:
04lariatfx4crewcab (03-04-2011)
post #10 of 21 (permalink) Old 03-04-2011, 03:22 AM Thread Starter
MOPSD250, thanks for the info, been looking for a rear sump oil pan not too many floating around. does anyone make an after market or aluminum one?
Hey did you ever get that harmonic ballancer issue worked out?
Jakob
Human Verification
fuel tank sump strokin6L General Ford Truck and Excursion 9 01-29-2011 05:51 PM
Fuel Sump midnight2004 2003-2007 6.0L Power Stroke 21 07-23-2010 05:52 PM
Fuel Sump for X S04X 2003-2007 6.0L Power Stroke 8 04-02-2010 03:04 AM
Hellmans Sump Dalpilot 2003-2007 6.0L Power Stroke 19 02-26-2010 07:23 AM
Hellman sump? bootcamp Supporting Vendors Forum 2 02-08-2010 11:15 PM
