1500 vs. 2500 Suspension - TheDieselGarage.com
Thread Details Posted by KYmxracer52, this thread has received 10 replies and been viewed 4798 times.
post #1 of 11 (permalink) Old 05-21-2010, 12:19 AM Thread Starter
I have a buddy that just bought a 07 1500 Mega Cab w/Hemi. He has the 8-lug axles. He's wondering what the difference is between his and the 2500's. He has the same number of leafs in the rear too. I told him I'd check on here and see if you guys could clarify it.
05 F-250 CC SB,Torqshift, 5" ProComp, 20x10 Fuel Hostage, 35" Federal Couragia M/T, B&W ball, MBRP 5" turbo-back, SCT X3, Edge Insight w/pillar mount, Truxedo roll cover*****SOLD***
KYmxracer52 is offline
post #2 of 11 (permalink) Old 05-22-2010, 12:40 AM Thread Starter
So no one knows the difference?
post #3 of 11 (permalink) Old 05-23-2010, 07:30 PM
Upside Swordfish
Sabbath5.9's Avatar
a 1500 with 8 lug???????
Jeff
1996 ram 2500 ex cab long 2wd, 5'' straight, 215s, 4k gsk(only revin till 3k), 16* timing, fuel plate MIA, afc modded FF, CFM intake mani, afe stage 2
15.40 at 90.61 in the 1/4th (09-18-10)
Sabbath5.9 is offline
post #4 of 11 (permalink) Old 05-23-2010, 09:43 PM
ADMIN/MAFIA
neeltburn's Avatar
The Mega Cabs have been like that from the beginning, What is the GVWR listed inside the door? I would imagine that it has fewer leafs in the rear and softer front springs.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #5 of 11 (permalink) Old 05-24-2010, 03:25 AM
Supporting Vendor
Skyd Ram's Avatar
They only difference is softer front and rear springs.
2010 CCSB Laramie Ram 2500 4x4
Powered By:
H&S/Shibby/Black Ops/Flo Pro
Suspended by:
Carli Suspension/Bilstein
2008 RCLB F250 XLT 6.4 Auto
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Pure Performance/Carli/Bilstein
Skyd Ram is offline
post #6 of 11 (permalink) Old 05-24-2010, 03:40 AM Thread Starter
I've not checked the GVWR. He said he has been looking under the 2500's he's come across, and they have the same rear leaf count as him. I agree that the front coils would be softer, especially with him having the HEMI instead of the Cummins. Basically, he wants to 'make' it into a 2500 for towing capabilities.
post #7 of 11 (permalink) Old 05-24-2010, 12:21 PM
PhilipR's Avatar
Rear springs will be a different rate.....they may have the same number but the rate is different. If he wanted a 3/4 ton for towing and what not why didn't he just buy the 3/4 ton? The frames are different as well IIRC between a 1500 and a 2500.
-Phil-
PhilipR is offline
post #8 of 11 (permalink) Old 05-25-2010, 12:59 AM Thread Starter
Its funny you mention that. I told him to just buy a Cummins for the mileage, and he showed up with that Hemi. He's getting about 10mpg driving easy. He never tows anything heavy, so he doesn't really need the 2500 leafs, but he would like to buy a used set cheap if he can find some. His GVWR is something like 3861?
post #9 of 11 (permalink) Old 05-25-2010, 03:24 AM
Supporting Vendor
Skyd Ram's Avatar
If he doesn't tow anything heavy then all that the 2500 leafs are going to do is make the truck ride worse.
Powered By:
Suspended by:
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Skyd Ram is offline
post #10 of 11 (permalink) Old 02-24-2011, 12:16 AM
jarek m's Avatar
I got an 07 1500 4.7 and tow a 16' 5k lb trailer to work every day. Jut put in Firestone bags in mine, it's night and day and when I get to the job site I drop the trailer, let the air out and its back to "Cadillac" ride while doing estimates all day.
Why not diesel? $$!!!!!!!!! I wish I could
Why not hemi? With my 4.7 I get 13mpg towing.
Time to look in to a conversion.
13,400lb of 2002 Chevy Express 3500 6.5TD
-Reloceted PMD
-Disc break conversion
jarek m is offline
Human Verification
285/75/16 on a 1500 6.5??? b_doornenbal 6.5L Diesel Engine 6 11-14-2009 02:54 AM
2500 Dmax or 2500 gas silverado? cetnor851 General GM Truck Forum 14 02-09-2008 04:21 PM
wanted 97 1500 Suspension Lift joebob3093 Whats Been Sold 1 06-16-2007 01:25 AM
500 ft lb at 1500 rpm?? Sader123 2003-2007 6.0L Power Stroke 8 01-01-2006 11:43 PM
99 1500 Deezle1 General GM Truck Forum 6 12-24-2005 02:54 PM
