05 runing rough open circuit on #2 injector - TheDieselGarage.com
Thread Details Posted by pinto7579, this thread has received 8 replies and been viewed 2195 times.
post #1 of 9 (permalink) Old 06-13-2010, 11:32 PM Thread Starter
when it started it would fade in and out. leading me to believe it was a wire. i found no bad wires but it cleared the code and would not run. got it back in the shop today primed the fuel system and it will run still showing open circuit on #2 injector any ideas
pinto7579 is offline
post #2 of 9 (permalink) Old 06-14-2010, 03:26 AM Thread Starter
read on another that injector was bad
i cant believe that a injector would be bad . because if a injector fails it fails which lead me to believe that it was a wire. but it could be in the computer. any help is appreciated
post #3 of 9 (permalink) Old 06-15-2010, 01:53 AM
duramax9878's Avatar
did u check there harness back further cause lly have 2 different spots that they r know to rub throw
Danny
2006 LBZ Chevy with 4in. straight back Duals, K&N Intake, EFI Live V2, PPE Standard, BD Exhaust Manifold, Mickey Tompson Tires and Auto Meter Gauges, Tie Rod Sleeves, Pitman Arm Braces, N Fab Nerf Bars, Recon Smoked Cab Lights, Halo Projector Headlights, and more soon.
duramax9878 is offline
post #4 of 9 (permalink) Old 06-15-2010, 03:12 AM Thread Starter
i think so pulled off most all of the wear guards found few spots that had small kinks but nothing rubbed though it ran fine for a short time with no codes and then I'm back where i started. thanks
post #5 of 9 (permalink) Old 06-17-2010, 01:56 AM
is there any fuel in ur oil
have u had the balanceing rates checked
Danny
post #6 of 9 (permalink) Old 06-17-2010, 11:02 PM Thread Starter
if you know where they rub could you give the location thanks i haven't tested the oil butt it not over full on the dipstick
post #7 of 9 (permalink) Old 06-23-2010, 10:55 PM
i beleive its by number 7 and 2
Danny
post #8 of 9 (permalink) Old 06-24-2010, 03:43 AM Thread Starter
thanks
i got to looking but still cant find it now showing high pressure on both fuel rails thanks
post #9 of 9 (permalink) Old 06-29-2010, 12:14 AM
i think u may want to get ur balancing rates checked to make sure its not ur injectors
Danny
Human Verification
Injector Circuit Low In 7 Cylinders? Fantom3993 2003-2007 6.0L Power Stroke 9 05-05-2010 04:25 PM
injector circuit low 2strokelover 2003-2007 6.0L Power Stroke 2 05-04-2010 01:44 AM
injector stuck open doob51 5.9L Cummins (2003-2007.5) 4 04-07-2008 12:50 AM
#7 injector open circuit NCJACKSONDMAX Duramax 2004.5-2005(LLY) 7 03-02-2007 12:36 PM
Injector Timming control Circuit Malfunction P0216 Gtownhound 5.9L Cummins (1998.5-2002) 7 01-30-2007 11:29 PM
