What is the best 6" Suspension lift for 03 2500HD??? - TheDieselGarage.com
Thread Details Posted by Bad Boy, this thread has received 13 replies and been viewed 11209 times.
Closed Thread
post #1 of 14 (permalink) Old 07-31-2006, 01:49 AM Thread Starter
I am thinking about lifting my 03 GMC Crewcab 2500HD Duramax and was wondering what is the best 6" Suspension lift kit for this truck to keep the best ride and steering angles? Also what is the best Tire Rim combo for this truck where it will not kill the fuel milage and rob any pulling power?
Bad Boy is offline
post #2 of 14 (permalink) Old 08-02-2006, 04:46 AM
tire burnin, smoke blowin
well i just lifted my truck with a rcd lift and it really rides like stock, the steering angles are like stock because of the taller cast iron knuckles that come with the kit keep the steering parts in the factory location. about rims and tires- the skys the limit. make sure whatever lift you get; the wheels have the proper backspacing so they dont rub on the new steering knuckles
01 chevy 2500hd plowtruck- boss v plow, airflow stainless v box salter, 305 MTRs, k&n, ppe boost valve(32psi), and diamond eye 4"exhaust, amsoil remote dual oil filter kit(bmk17)
02 chevy 2500hd ccsb- RCD 6" lift, fabtech inner & outer tierods, cognito pitman & idler arm supports , k&n gen 2 intake w/afe pg7 filter, banks 4" exhaust, 315/75/16 BFG A/Ts on centerline rims, amsoil remote dual oil filter bypass kit(bmk17) nicktane billet filter head and 2 micron cat filter. edelbrock 1792 liftpump w/hobb switch, moonshine tuning (500+rwhp),lbz cp3, suncoast trans stage 4 w/1057 converter.
05 honda trx 450R quad - sand dune/wheelie machine, honda racing cam, snorkel, airbox and exhaust
dmaxvaz is offline
post #3 of 14 (permalink) Old 08-02-2006, 05:17 PM
Another vote for RCD here.
2003 Chevy 2500 CC SB 6'' RCD Lift, 35" BFG's, Roll-N-Lock, PPE Tech IV, 4" Banks exhaust, and K&N Intake
1982 Chevy K10 SB 350 4 bolt main, SM465, NP208,
4" Lift and 35" mud Tires
hdroadkingc is offline
post #4 of 14 (permalink) Old 08-03-2006, 12:57 AM
hey hdroadking, i was wondering what width rim did you use? i have 16x10 and 305/70/r16 rims/tires on my truck now and im thinking about putting 315/75/16 toyo open country m/t on the current rims, but im wondering if they will rub on the front bumper? how much are the torsion bars cranked up on your truck? thanks in advance
dmaxvaz is offline
post #5 of 14 (permalink) Old 08-06-2006, 01:07 AM
slam^50
well i have a fab tech 6 in lift and i like it the truck rides great. about the wheels as said above make sure you get proper back spacing i have 325x60x20 toyo open countrys on my truck ,and the back space is off just a little bit and on sharp left turns the right front tire rubs the sway bar.my pics are in the photo gallery red gmc.
slam^50 is offline
post #6 of 14 (permalink) Old 09-06-2006, 06:50 AM
i have a procomp kit with dual shocks and love the ride 37 bfg muds with cut out flares
greenduramax is offline
post #7 of 14 (permalink) Old 12-14-2006, 12:35 AM
I thought I knew that?
My vote is for RCD as well. It is BETTER than stock IMO.
gasco is offline
post #8 of 14 (permalink) Old 12-14-2006, 05:55 AM
cut the bumper with a plasma cutter, take a sawsall to the fenders and buy flares then go to a good tire wheel guy. i can fit 35's w/ no lift.
mckey73 is offline
post #9 of 14 (permalink) Old 01-11-2007, 02:26 AM
Not calling you a lier or anything but i would love to see those tires fit with no lift, i have 16 inch cepek rims with 35s mickey thompsons on, with a 3 inch lift and its tight as a mo-fo. i would love to see pics if you have any
Sweiny is offline
post #10 of 14 (permalink) Old 01-11-2007, 03:48 AM
Another Vote 4 Rcd
2006 DURAMAX 4X4 4 INCH SILVERLINE AFE INTAKE HYPERTECH PROGRAMER 6 INCH RCD 20 INCH KMC HOSS:evil:
BIG CHORIZODMAX is offline
Closed Thread
Human Verification
