LB7 Cold Start Problems. HELP PLEASE - TheDieselGarage.com
Thread Details Posted by 2500HD03, this thread has received 13 replies and been viewed 5849 times.
post #1 of 14 (permalink) Old 10-13-2009, 02:17 AM Thread Starter
So i'm new to the duramax's I have had cummins till this. I got my new pickup and just after buying it found that i had bad injectors took it to the dealership to get them done under warranty. Got pickup back and truck ran great and everything. I let it sit over the weekend though and started it up truck ran for about 2 sec. and then died. Crank and no start. Opened the hood and pumped the fuel primer a few times and it fires right up. Well now that it is getting colder it does this about every morning. I read a post that the duramax does not use a lift pump? is this correct, i'm a diesel mechanic and the only engines i've ever seen that do not use a lift pump is one with the tank above the engine, AND A SMALL ENGINE aplication at that. I would think that the cp3 pump would need something helping feed it. Is there one in the tank. Also if there is no lift pump how come there is aftermarket lift pump options for the duramax. Also hooked up a snap on modis and there are no stored codes. Sorry i did not have the opportunity to hook it up on a cold start though to monitor pressures. I would think if they caused an air leak in the system it would have some running issues when i first got it running. But i just pump the primer a few times and it fires right up, no smoke or nothing.
03 2500HD CC, SB, 4X4
STOCK OTHER THAN A GUTTED MUFLER
2500HD03 is offline
post #2 of 14 (permalink) Old 10-13-2009, 03:24 AM
Pardue the Traveler
New 0mega's Avatar
It is true that the Duramax does not have a lift pump on the truck the CP3 pump draws the fuel by vacuum. Make sure your fuel filter is on good, if the fuel line sucks air then it will not flow properly to the engine. There are aftermarket lift pump options because there is no lift pump. You might have to run an anti-gel till you are able to get a batch of winter diesel.
Canadian Club member #2 http://www.thedieselgarage.com/forum...light=Canadian
Singles Club member #250
http://thedieselgarage.com/forums/image.php?type=sigpic&userid=23125&dateline=124580  0528
For those whom are looking at a Duramax check this thread out.http://www.thedieselgarage.com/forum...ad.php?t=92868
New 0mega is offline
post #3 of 14 (permalink) Old 10-13-2009, 04:05 AM Thread Starter
Thanks, for the info. By cold start i don't mean cold enough to need anti jell. I just mean sitting for 12 hours. temp is only been like 40 f. I don't think it is sucking air at the filter though because I've seen this on other diesels and when they suck air they run bad till air clears. This shuts off like you turned the key off. And then once you pump fuel back in a few times it starts normal and runs normal. (i don't mean it cranks and cranks then starts) Sorry I'm not trying to say your wrong just trying to add more info on the problem and discuss reasons.
2500HD03 is offline
The Following User Says Thank You to 2500HD03 For this addition to TDG:
New 0mega (10-13-2009)
post #4 of 14 (permalink) Old 10-13-2009, 05:06 PM
Pardue the Traveler
New 0mega's Avatar
I was just going to the most common won't start problem, air in the fuel line.
If you are thinking of getting a lift pump, I'd go for a Fass or Airdog 2, cause they add an extra filter and a water separator which is always a bonus.
post #5 of 14 (permalink) Old 10-13-2009, 05:16 PM
TDG Mafia Goon
BombDocDiesel's Avatar
I'm still betting on the filter. This is kind of how that works. I know a lot of us have thought we the fuel filter on tight enough to have these kind of issues.
Also, warm truck and hot engine bay with even the slightest of air leaks equals cold moist air drawn in the leak.
I will second the AirDog, but you probably won't need it until you do some tuning.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #6 of 14 (permalink) Old 10-14-2009, 05:10 AM Thread Starter
Pulled it in the shop today to take a look myself. First time i have had time to look at it since the dealer did the injectors. The fuel filter is on tight, i thought maybe they forgot to put a clamp back on a rubber line, but they were all on and good. I could not find anything. I was able to push the quick coupler line ( in front of the drive about at the valve cover.) in a little tighter, but it was connected correctly so i don't think this was it. Is there a check valve in the cp3 pump? That is about all that makes sense to me. It only happens when it sits for extended periods of time. I just cant see a filter issue because a leak at a filter gets worse when running because it would actually be under a vaccum. Say like 10 lbs vaccum pressure trying to suck air through the leak. But engine off it would just go to 0. If a filter was at cause this should be present while running and definately under a load shouldn't it? But if it were a check valve in the cp3 (i dont even know if they have one) once it were running the check valve would not matter because it would be open anyhow. But once off if it were stuck slightly open the fuel could drain back out of the pump and into the tank causing it to start but die quickly and not start again untill fuel is reprimed back up to the pump. Then it would run fine.
Were do you guys put lift pumps on these? Just somewhere between the tank and fuel filter?
Thanks again for feedback
2500HD03 is offline
post #7 of 14 (permalink) Old 10-14-2009, 04:48 PM
Pardue the Traveler
New 0mega's Avatar
There is a problem with leaving these trucks sit for a long period like you said. You can install a lift pump/Fass/Airdog 2 on the frame in front of the rear tires.
post #8 of 14 (permalink) Old 10-14-2009, 05:16 PM
TDG Mafia Goon
It loses prime. Still sounds like a leak or hole. Take it back to the shop that did the injectors. I will ask this to some Duramax guys that may have seen this before.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #9 of 14 (permalink) Old 10-14-2009, 06:16 PM
TDG Mafia Goon
A fuel leak from injector lines could do this. Did you check the oil level? If your oil level is rising, it could be leaking under the cover and into the pan.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #10 of 14 (permalink) Old 10-14-2009, 11:03 PM
TDG Mafia Goon
If the oil is good try this.
Pump up the primer several times and look for fuel leaks at the filter housing area and at the fuel inlet and return line area at the drivers side of engine.
Your leak is most likely outside engine. Check bleed screw o-ring and then never touch it again. Check filter housing rubber hose connections and fuel connections at the FICM (right behind the alternator) these are most of the places that they could have touched when doing the injectors.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
Human Verification
Cold Start Problems smryan3326 5.9L Cummins (2003-2007.5) 11 10-27-2010 06:51 PM
cold start problems stacks 2003-2007 6.0L Power Stroke 16 03-25-2009 02:44 AM
OBS Cold start problems Mt.Washington7.3 1994-2003 7.3L Power Stroke 6 02-15-2008 10:59 PM
cold start problems!! 1100hpfox 7.3L and 6.9 IDI (Pre 1994) 2 01-02-2008 02:13 PM
Cold start problems imported_whitelightning 1994-2003 7.3L Power Stroke 8 10-21-2006 01:19 AM
