6.5 turbo starter issues - TheDieselGarage.com
Thread Details Posted by All American, this thread has received 4 replies and been viewed 8278 times.
post #1 of 5 (permalink) Old 11-14-2010, 09:42 PM Thread Starter
This has happened on my 6.5 non turbo and my 6.5 turbo trucks... The starter seems to want to push away from the flex plate when cranking, and ends up sliding over just enough to not mesh properly, and causing a laundry list of problems; chewed up starter teeth, flex plate teeth, pulling out the starter bolt threads, the non turbo even cracked the back of the block just behind the bolt holes for the starter! I have the little bracket on the front of the starter to the block on there. Any suggestions? I have 2 dead trucks for the same issue! I have to believe this is somewhat common and someone here has dealt with it! Thanks
All American is offline
post #2 of 5 (permalink) Old 11-15-2010, 03:22 AM
M123KT-450's Avatar
yep i have been here before, there is a bracket at the back of the starter that should bolt the starter to the block i believe lot's of guy will leave it off cause it is a true pain the i can't say that here . . .
Anywho what happens is after a while of running without the bracket you'll break one bolt or the other some time it'll just oblong the starter bolt holes and allow it to move back . . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #3 of 5 (permalink) Old 11-15-2010, 03:40 AM
M123KT-450's Avatar
GM-6.5 diesel starter bracket stud:
I tired my best to find you a photo of the actual bracket itself but i couldn't find one
hope i was of some help to ya
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #4 of 5 (permalink) Old 11-15-2010, 06:26 AM Thread Starter
Thanks Mike, you actually confirmed my suspicions. I do have that bracket on there. The previous owners of both trucks did not. When I had the first truck (the non turbo) I noticed the mounting point on the starter as indicated in your image, then searched and located the block mounting point. After a little research I found the bracket and have now installed them on my trucks. But my worry is as you said, the damage to the holes is already done! My only other thought is time certs, I just hope I can get them in properly with oblonged holes to work with.
post #5 of 5 (permalink) Old 11-15-2010, 10:28 PM
M123KT-450's Avatar
See what you can do about some incerts worst case ya may have to replace the front section of the starter
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
Human Verification
Starter Issues BUCK2 5.9L Cummins 12 Valve (1994-1998.5) 11 09-04-2010 12:48 PM
starter issues JPscustoms 2003-2007 6.0L Power Stroke 4 03-05-2010 09:33 PM
Starter Issues rsjohnsn 2003-2007 6.0L Power Stroke 5 04-12-2009 01:34 AM
Starter issues!! IDITurboPuller 7.3L and 6.9 IDI (Pre 1994) 20 08-20-2007 02:50 PM
starter issues jersey250 2003-2007 6.0L Power Stroke 1 02-15-2007 10:18 PM
