Anyone Cap off the Oil Cooler Lines? - TheDieselGarage.com
Thread Details Posted by argo, this thread has received 0 replies and been viewed 2018 times.
post #1 of 1 (permalink) Old 05-26-2011, 03:55 AM Thread Starter
Gran Turismologist
argo's Avatar
First off: Sorry I've been gone for a while, but I have been crazy busy at work. I have a question I have been pondering lately and wanted to see if any of you have any experience with this.
How many of you have capped off the oil cooler lines on your engine? If so, did you remove the cooler bypass valve? I do not use my Suburban for towing. I have my F-150 for heavy work... the most this will ever carry is 8 people and luggage, so the potential for leaks is not worth the risk. The reason I ask is because I am not thrilled with my hot idle oil pressure. My line ports are capped, and at hot idle I only have about 15-18 PSI oil pressure. According to my GM service manual 10 PSI is the hot idle spec, but I would like to see over 20 PSI at hot idle. I am not worried, but I still don't like it. Oil pressure is fine at higher RPM. At 60 MPH I turn 1800 and I have 40 PSI, and at 75 MPH I am turning 2250 RPM and I have just under 60 PSI. I think that the bypass valve is costing me some pressure especially at idle, and I'd like to remove it. Has anyone ever done so, and if you have, what do I need to do? The Service manual is quite vague about the procedure, so any guidance anyone can offer will be greatly appreciated.
1993 Suburban 2wd 6.2L Diesel Conversion "Andromeda":
3.73:1 gears, THM 700-R4 transmission, and
J-code 6.2L diesel from a 1984 C2500 Suburban
1996 Ford F-150 4x4 300ci Inline 6 "The Argo"
327,000 miles and climbing
1992 Caprice Wagon 5.0L TBI "Enterprise-D"
Originally Posted by Mater View Post
Ah ha ha ha! I swear! Tractors is so dumb!
Originally Posted by General Nazca View Post
The Argo? That ridiculous pile of scrap metal!
argo is offline
Human Verification
tranny cooler lines Cozy Homes D-MAX GM Transmissions 13 06-10-2009 04:34 PM
trans cooler lines spok 1994-2003 7.3L Power Stroke 1 04-30-2008 06:31 PM
Oil cooler lines/hose hauling4you 6.2L Diesel Engine 7 12-31-2007 11:14 PM
beware the tranny oil cooler lines dangerous196 5.9L Cummins 12 Valve (1994-1998.5) 6 11-15-2007 02:31 AM
Trans cooler lines?? BuyAmerican Supporting Vendors Forum 2 02-09-2007 04:20 AM
