6.2 starter bolts - TheDieselGarage.com
Thread Details Posted by kstmg04, this thread has received 9 replies and been viewed 5610 times.
post #1 of 10 (permalink) Old 11-16-2007, 05:48 PM Thread Starter
6.2 starter bolts
ive been having problems with the starter bolts breaking off in the block of my 6.2... this has happened twice before and weve had to change the block once because of this... any suggestions ?
kstmg04 is offline
post #2 of 10 (permalink) Old 11-24-2007, 01:52 PM
geeze, this section is a ghost town. guess it means no one is having 6.2 issues. there are two reasons to have starter bolt issues. one is the bolts are loosing over time. the other is that the front bracket that bolts the starter to the block is missing. the bolts to both the starter it self and the bracket hould be removed and cleaned with gas,brake cleaner ,etc. reinstall and trq them pretty well. i dont have the specs infront of me, but 80lbs seems to be what i remember. the little bracket on the front of the starter is the main issue, many shops make the mistake of not reinstalling it when doing starter work. this is a nono, the starter is very heavy and needs support up front. if you dont have the bracket, see a dealer ..
navistar45 is offline
post #3 of 10 (permalink) Old 11-30-2007, 01:44 AM
It isn't so much the weight, but the torque. When the starter is doing it's job, it torques upward, and that bracket is there to keep it from nosing up like that. Without the bracket to stabilize, the rear of the starter moves down away from the flywheel, breaking bolts, starters, flywheel teeth, all that kind of fun stuff.
The workhorse: 86 F250 6.9 4 speed 4wd 4.10 gears, electric fuel pump
The other workhorse: 92 F350 2wd crew cab, 92 6BT Cummins, NV4500 and GV overdrive unit, 4.10 rear axle
fellro86 is offline
post #4 of 10 (permalink) Old 12-04-2007, 02:52 AM
Thanks for the info. My started bolts broke off two weeks ago and luckily the second one broke in a hardware parking lot. I was able to back out the broke off parts of the bolts. (no easyout required, I should have bought a lotto ticket) I was able to buy and install tempary bolts untill I could get hardened bolts, but was able to get home. I put over 30,000 miles on the truck and never knew there was suppose to have a front bracket until I heard it here. I will get one ASAP! Thanks, Dennis
50 Burb is offline
post #5 of 10 (permalink) Old 12-12-2007, 02:19 PM
A believer in Christ
Send a message via MSN to dieselolds
Keep in mind that the 6.2 starter bolts are metric and are of a specific size.Starter bolts as those used in chevy 305,350 engines are not the same(smaller diameter) and should not be used in the 6.2 diesel.
1993 Chevrolet K1500 pickup
-Equipped with 1981 5.7L diesel (DX block)
-.030 oversize sealed power pistons
-Total seal piston rings
-ARP fasteners throughout
-Under-drive aluminum pulleys
-High performance oil pump driveshaft
1979 Chevrolet K20 pickup
-Equipped with 1978 5.7L diesel (D block)
dieselolds is offline
post #6 of 10 (permalink) Old 01-08-2008, 05:51 PM Thread Starter
hey just wondering if you guys would normally use hardened steel bolts or use a softer material bolt.
kstmg04 is offline
post #7 of 10 (permalink) Old 01-08-2008, 09:17 PM
I would go with hardened, but the factory bolts have a kind of knurl on them that helps keep them from loosening. You also have to watch the depth, if you bottom out the bolt, they are way harder to get out than if you break them off not bottomed. You could also think they are tight, but not be.
fellro86 is offline
post #8 of 10 (permalink) Old 01-17-2008, 03:47 AM
I went to the dealer to get factory bolts and needed to double washer one of them because of bottoming out. Make sure the front bracket is tight. That was how mine bolts broke.
50 Burb is offline
post #9 of 10 (permalink) Old 01-21-2008, 02:01 AM
The knurl is to help "fill the hole" in the housing. Other wise the excess play will result in broken bolts or a starter housing.
INLINE6 is offline
post #10 of 10 (permalink) Old 03-04-2008, 06:07 AM
Anyone have a part # for that starter brace bracket? Does the 6.5 engine take the same piece? I think this is so common for it to be missing, that this is news to many of us! There are 4 GMC 6.2/6.5 diesels on this job site, I looked at every one of them- not a front starter brace in the bunch. My inquiry as to that part was met with, Huh?
1984GMC is offline
Human Verification
