Towing with a bus...?s - TheDieselGarage.com
Thread Details Posted by JakeC, this thread has received 9 replies and been viewed 1770 times.
post #1 of 10 (permalink) Old 12-07-2009, 01:33 AM Thread Starter
I have a '91 66 pass. bus that I am converting into a camper. It is built on the International 3800 chassis. I plan on towing a car trailer with it. My concern is the amount of overhang with a 66 pass. bus. Will this throw a typical car trailer around too much, so to speak? What about tongue weight? The hitch will have a LOT of leverage due to how far it is from the axle. Do any of you think this will be a concern? Anyway, here is a pic of it. Let me know your thoughts.
1991 International bus with 210hp dt466, Allison 643 tranny, and 4.78:1 rear.
JakeC is offline
post #2 of 10 (permalink) Old 12-07-2009, 02:57 AM
7.3 addict
need more info on trailer.
1) 99 f-350 srw 7.3 6pos. bully dog, afe intake, mrbp 4" exhaust,250,000 miles and still rollin.
2) 2000 excursion 7.3 afe intake, mrbp 4" exhaust. chip coming
3) NEW TO ME2000 cc drw 7.3 let the mods begin
4) FOR SALE 87 f250 6.9 9' utility body.
5) SOLD 91 f150 good truck just well used.Gonna miss the old girl allways started even after sitting for 6 months.
I think i'm trailer poor ) 22' w\18' tilt car hauler, 18' flat bed, 2 horse D&D, 12' utility, 19' "v" nose, and 37' 5er
"quote from tank"
"I use baby wipes.....
Because if you think that a wadded up piece of paper is actually getting the chit off of your butt.....then I have to ask a question....
.....if you wiped a turd on your arm....would you just use a paper towel to get the turd off?.....or would you wash your arm?...
...let that thought roll around in your head for a moment...
" thank you tank for that insightful thought
#46 AMERICAN (blood) club
#241 singles club
# ? Dually club
# ? Excursion club
jestersv is offline
post #3 of 10 (permalink) Old 12-07-2009, 05:16 AM Thread Starter
I don't have a trailer yet, but I will be looking for a tandem axle car trailer. Weight will likely be well under 10,000lbs(trailer, rock crawler, and gear). Length will prolly be around 16-18'. I'm just talking about a typical car trailer that would be towed behind a pickup.
JakeC is offline
post #4 of 10 (permalink) Old 12-07-2009, 03:45 PM
I dont know how much overhang you have but i have a 36 foot class a rv and i was thinking the same thing as you but i tow a 28 foot car trailer with no problem. The bakc of the frames on most rv's dont look the beefyest but i havent had a problem yet.
Alex
03 f250 FX4 55,000 miles
-stock
99 F-350 4x4 CC LB 250,000 miles
-leveled w/ 315-75-16's
-4'' dp to 5'' stack
-CAI
-bullydog 6 pos
-D66 turbo
Stroked383 is offline
The Following User Says Thank You to Stroked383 For this addition to TDG:
JakeC (12-07-2009)
post #5 of 10 (permalink) Old 12-07-2009, 06:50 PM Thread Starter
I probably have around 10' of overhang, maybe a little less. That helps though, thanks! Not to worried about the frame, my rails run all the way to the back...LOTS of beef!!
JakeC is offline
post #6 of 10 (permalink) Old 12-12-2009, 09:00 AM
I have towed with a Bounder MH and if the trailer is not well mannered the leverage really bites. My cure was a Reese hitch with sway cams.
You will have to secure stuff because of the amount of bounce is more than a pickup, my toolbox fretted a spot in the floor.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #7 of 10 (permalink) Old 12-15-2009, 08:10 PM
Supporting Vendor
I have heard good things about the Trailer Toad, which provides another set of wheels to take the tongue load.
Way back in the 1980's, I knew a guy who raced in Super-Gas, and had a similar bus for a tow rig. He carved up the back of the bus and made a semi-open "garage" back there, and drove the car up there. Wish I had taken photos, it was REALLY redneck!
Regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 271k miles
10 ISSPRO Prototype Performax™ gauges in Pillar & Overhead pods & sitting on dash, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Baby Swamps, Swamps tunes, Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
1998 S&S 9.5' slide-in camper
32' enclosed tag trailer with 2 drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
2000 VW Jetta TDI - Kerma tune, Der Chimera Stage II Clutch
NRA member and certified firearms instructor, GOA Life member, IDPA member
Michael is offline
post #8 of 10 (permalink) Old 12-15-2009, 10:01 PM
Repository of Diesel Info
Send a message via AIM to Haloman
We tow quite a few trailers with our service bus.
Haloman is offline
post #9 of 10 (permalink) Old 12-16-2009, 02:22 AM Thread Starter
Thanks guys! I need to be able to do this without carving up the bus, since it's getting turned into a camper. I'll have to look at the sway cams.
JakeC is offline
post #10 of 10 (permalink) Old 02-23-2010, 10:31 PM
Weight distributing and sway controlling hitch is what you need, as was said, but keep the trailer as light as possible. The leverage really is a killer. Another thing to consider is that even without a trailer the back of a school bus can come real close to the ground going in and out of driveways, etc.
Machinos is offline
Human Verification
Towing with the 310. George C 2008-2010 6.4L Engine Tuner Forum 23 05-20-2009 06:17 PM
towing?? jduramax Duramax 2001-2004 (LB7) 12 09-26-2007 12:13 AM
towing in O/D youngPSD Towing and Hauling 11 08-02-2007 07:38 AM
Towing with TS 5X Dieselman 2003-2007 6.0L Power Stroke 22 03-15-2006 06:37 PM
Towing... SICKS-O 1994-2003 7.3L Power Stroke 1 03-13-2006 04:28 PM
