Opinions ? - Benz L6, 12.8L - TheDieselGarage.com
Thread Details Posted by bushpilot, this thread has received 5 replies and been viewed 6326 times.
post #1 of 6 (permalink) Old 08-15-2010, 02:37 AM Thread Starter
bushpilot's Avatar
Any thought or Opinions on the Benz 12.8L ?
Im looking at a renegade coach that is built on a Freightliner Columbia chasis
and uses a 12.8L (450hp) w/ an AutoShift 13 speed UltraShift (large paddle,
turn signal stalk style).
Any thoughts or known history w/ these Engines & Transmissions ??
Don R.
Truck Audio,
bushpilot is offline
post #2 of 6 (permalink) Old 08-15-2010, 03:21 AM Thread Starter
bushpilot's Avatar
the tranny is an Transmission: Eaton/Fuller 13 speed (auto) Ultrashift
Don R.
Truck Audio,
post #3 of 6 (permalink) Old 08-20-2010, 02:58 AM
Euro Sparky/ Wrencher
french277's Avatar
IMO ils sont ok mais les parties sont chères sur des moteurs diesel Benz somecase il peut avoir backlogged pour des parties, mais la plupart de cas ils sont allright à moi.
La durée d'utilisation sur le moteur ce que j'ai entendu ils peut aller n'importe où 800Ko à 1M des miles avant que vous ne fassiez rien des réparations majeures sur cela.
IMO they are ok but the parts are expensive on Benz diesel engines somecase it may have backlogged for parts but most case they are allright to me.
Service life on the engine what I heard they can go anywhere 800K to 1M miles before you do anything major repairs on it.
Merci.
Marc
Pas de problème,il marche n'est-ce pas?"(No problem, it works doesn't it?)
french277 is offline
post #4 of 6 (permalink) Old 08-20-2010, 01:03 PM
OTT
are fleet has 3 of these engines. We are lucky to get 400,000 miles out of one before they need replaced. The heads start to move and screw up the block. My friend that works at the local detriot dealer has been doing 4000 series engine swing for the past few months. Check to see if there is any leaking coolant from the head gasket on the right side of the engine behind the turbo. If there is run from it!
2011 389 c-16 stage 2 tune stage 2 injectors stage 3 cam stage 3 turbo Coming soon Twin turbos!
07 379x 625 mxs, stage1 pdi tune,pdi manifold
07 chevy 2500, efi tuned by the master Idaho Rob, 5" exhaust,Tranny built by myself with stage 4 suncoast parts tc1056
PDI dealer in Nebraska
"If I wanted a 7cz tune file I would buy a 7cz"!
The Name Is Dusty AKA Mr.Young Dealer
OTT is offline
post #5 of 6 (permalink) Old 08-28-2010, 06:15 PM
PGM
Fleet Owner
PGM's Avatar
Im currently running 2 of these engines in Sterling trucks, and have had no problems with them at all, although they are both young still, 250,000kms and 140,000kms, i run at 45ton with them.
My only complaint would be that they are a bit "lazy" and dont like to move in a hurry.
Once moving they hold on ok.
Mine are both set at 450hp and 1550ftlb, and when i say lazy, my ISM cummins's set at 425hp and 1450ftlb walk away from them, and accelerate much quicker.
I do get good fuel economy with them though, and i average 3kmlt+ around the city with them all day long in stop-start traffic.
94 Kenworth K100E Detroit 470hp.
94 Kenworth T650 Cat 3406C 425hp.
96 International S3600 N14 460hp.
09 Sterling LT9513 MBE4000 450hp.
08 Sterling LT9513 Detroit 575hp.
07 Sterling LT9513 Detroit 500hp.
07 Sterling LT9513 MBE4000 450hp.
07 Freightliner Columbia 120 Cat C15 550hp.
06 Sterling LT9513 ISM 425hp.
05 Sterling LT9513 ISM 425hp.
04 Sterling LT9513 ISM 425hp.
04 Sterling LT9513 Detroit 500hp.
03 Sterling AT9513 Detroit 470hp.
___________________________
PGM is offline
post #6 of 6 (permalink) Old 09-03-2010, 05:41 PM Thread Starter
bushpilot's Avatar
well i lost the opportunity on the one and came across another...double rear axle,
cant say i trust the seller...he's come off VERY VERY grease in his communications,
photos and "dealings"
i continue to look & feel a bit more comfortable w/ the engine & tranny...in a motor coach
ill NEVER stress the motor (other than via my heavy foot) like it was intended to be
run so i think ill be ok...the insurance and labor rate on these coaches is considerably
less than a pusher bus...just need to drive one so i can compare for comfort and noise.
i figure the air ride seats will be a welcome advantage in these coaches (renegade or
haulmark) over conventional <non air> seats in a pusher bus/coach
Don R.
Truck Audio,
Human Verification
Wicked Benz Diesel Timbeaux38 The Parking Lot 7 05-03-2009 11:27 PM
Mercedes Benz High Mileage Award ymmot Euro-Diesels 22 04-12-2008 03:07 AM
W124 Benz HighTQCummins Video Discussion & Support 9 02-27-2007 12:55 AM
2006 diesel benz question ngc414 Euro-Diesels 4 06-16-2006 11:29 PM
Mercedes-Benz E500 Wagon ymmot Road Kill, Bench Racing 3 03-18-2006 04:02 PM
