Cummins ISX has FSS Derate - TheDieselGarage.com
Thread Details Posted by junebug, this thread has received 43 replies and been viewed 34949 times.
post #1 of 44 (permalink) Old 09-01-2010, 08:13 AM Thread Starter
I have a 2001 ISX CM 570. It has a stall at full throttle in every gear above 6. I notice it mainly in top gear around 1350-1400 rpm thru 1650 rpm. I did an Insite log to see what was going on. The user fueling state shows both an AFC Derate and a FSS Derate. I think the AFC is due to boost pressure being low(the boost sensor looks like it may be sticking), but I have no idea what causes the FSS Derate. The FSS Derate is the one causing the stall in top gear and the one I'm trying to diagnose and correct.
junebug is offline
post #2 of 44 (permalink) Old 09-01-2010, 11:00 PM
tc2
the AFC derate is not enough boost and can be acceptable for up to 10 seconds at full load.. other than that needs looking at.
i can't find any info on an FSS derate.
there is a fuel system derate caused by an active fuel system fault, or a fueling high speed governor state which means the engine is at max. RPM.
try calling Cummins at 1-800-diesels and asking about that user fueling state. apparently there are about 80 user fueling states in total.
tc2 is offline
post #3 of 44 (permalink) Old 09-06-2010, 07:38 PM Thread Starter
I called Cummins and they said they have never seen an FSS derate. Thet also couldn't tell me what the abbreviation was for. I have also talked to a few Cummins techs who don't know anytging about it either. I have very little confidence in Cummins techs anyway.
junebug is offline
post #4 of 44 (permalink) Old 09-07-2010, 05:05 AM
pichu2's Avatar
is not FSS is FFS is you need chance fuel filter? FUEL FILTER SERVICE i check my manual
pichu2 is offline
post #5 of 44 (permalink) Old 09-07-2010, 05:15 AM Thread Starter
The fuel filters are new. Besides I can read and it is FSS not FFS. Its not a fault and there are no active or inactive codes being thrown. Its a user fueling state that happens during Maximum Fueling state.
junebug is offline
post #6 of 44 (permalink) Old 09-07-2010, 05:32 PM
mrdevildog's Avatar
whats your engine serial number?
mrdevildog is offline
post #7 of 44 (permalink) Old 09-07-2010, 07:06 PM Thread Starter
ESN 14012552. 2001 ISX CM570
junebug is offline
post #8 of 44 (permalink) Old 09-07-2010, 10:41 PM
tc2
did you call the local Cummins dealer, or the 1-800 number?
the 1-800 number is for cummins corporate.That's the same number a tech calls for troubleshooting help once the engine is out of warranty. they should be able to look up all of the user fueling states or call engineering to find out.
tc2 is offline
post #9 of 44 (permalink) Old 09-07-2010, 11:24 PM Thread Starter
I called Corporate first. They said they had never seen an FSS derated user fueling state. They also couldn't find any info on what the FSS abbreviation stands for. All of the distributors just want me to come in and see them for 102 an hour. They also say there needs to be an active code for a derate, but Insite says no codes either active or inactive.
junebug is offline
post #10 of 44 (permalink) Old 09-08-2010, 12:25 AM
tc2
yeah I couldn't find any info on an FSS derate either.
And no, you don't need an active code for the derate. There are quite a few derates that do not set a code.
It might not hurt to get the ecm flashed to the latest version. At least you might wind up with a user fueling state that makes sense.
It looks like your ecm code should be N10184 that code is up to version 28 now. version 23 and 24 were supposed to fix a 'stumble' which might help you as well.
The ecm code can be found in insite in the features and parameters page in the first section.
tc2 is offline
The Following User Says Thank You to tc2 For this addition to TDG:
junebug (09-10-2010)
Tags
cummins performance, stall
Human Verification
Looking to buy my first Cummins 12V OzarkSaints General Dodge Discussion 4 10-09-2009 12:21 PM
do they derate F350 C&C's? FordRacing200 2008-2010 6.4L Power Stroke 13 07-11-2007 11:40 PM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Diesel Conversion 0 05-23-2007 05:29 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Whats Been Sold 0 05-23-2007 05:29 AM
Cummins guy needs help (for my dad!) bsplyr500 1994-2003 7.3L Power Stroke 21 03-08-2007 02:57 PM
