444 Cummins - TheDieselGarage.com
Thread Details Posted by mbj359, this thread has received 15 replies and been viewed 11763 times.
post #1 of 16 (permalink) Old 01-04-2011, 04:12 AM Thread Starter
444 Cummins
I am looking at a truck to purchase that has a 444 Cummins in it. I have heard good and bad on the 444. Does anyone have any experience with this engine good or bad?
mbj359 is offline
post #2 of 16 (permalink) Old 01-04-2011, 04:22 AM
Big Cam Power!!!!!
LOG HAULER's Avatar
What is the cpl?
Get right before you get left!
91 Taurus SHO 220hp
2005 GS 430 300hp
1985 Freightliner FLC Big Cam 350 No Mods Yet
1979 Kenworth W900 Big Cam 550Hp
If it aint something it's something else!!
Add Me on FACEBOOK .....ROC KENWORTH
LOG HAULER is offline
post #3 of 16 (permalink) Old 01-04-2011, 11:56 AM Thread Starter
Dont know yet. The truck is long distance from me. I will try to find out.
mbj359 is offline
post #4 of 16 (permalink) Old 01-04-2011, 06:26 PM
SledMan's Avatar
Run Forrest...Run!!!!
Seriously, just like all older Cummins, they are prone to leaking head gaskets. They also had step timing which also gave some trouble. I'm not a Cummins fan, but I have had customers with 444's, and ALL, not just some, had problems over the years.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks:1980 KW Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. 2003 Pete EXHD. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3025 squirts. 800 cam. Acert twins via custom mount. ARP head bolts.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline
post #5 of 16 (permalink) Old 01-04-2011, 06:37 PM
The other guy
ynot is offline
post #6 of 16 (permalink) Old 01-05-2011, 10:18 PM
A 444 is an engine that needs a lot of tender loving care to get it to run correctly, there are a lot of pieces that make the STC operate properly, and any leaks in the system cause problems.
I use to do a lot of work on these units, and customers that ran them seemed to make money.
They are not high on my list engines I would chose but that depends on whether you can get it cheap, and find someone that works on them, cheap, or know how to do it your self.
Johnp3 is offline
post #7 of 16 (permalink) Old 01-06-2011, 03:10 AM Thread Starter
Thanks for the advice. I bought the truck and will take my chances. I have several Cummins gurus close to me if I need them. The truck is long distance from me and not sure when it will be here. I have pretty much run Cats to this point and am willing to try this Cummins. It is hard to pass up a two stick 359ExHd.
mbj359 is offline
post #8 of 16 (permalink) Old 01-06-2011, 03:17 AM
379Longhood's Avatar
You will have to relearn your shift points 444 s are 1700-2100 engines. if you can keep the step time figured they are an allright engine,
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #9 of 16 (permalink) Old 01-06-2011, 03:27 AM Thread Starter
Thanks, I have heard alot of good and bad on them. This truck is very original from the factory and I just had to try it. I have run 2 stick cats and liked them very much but this will be different for sure. The truck will not be worked daily more for farm and hobby use.
mbj359 is offline
post #10 of 16 (permalink) Old 01-08-2011, 01:29 AM
Thumbs up
The 444 is a glorified 400 big cam. they hang together as good as any of the nh series. It will run with the 425 cats. If you retro fit a decent after cooler in front of the radiator and take the guts out of the old intercooler, you gain a few more horses! Thats what it is all about.
broncobob is offline
Human Verification
cat or cummins cat power Diesel Conversion 18 02-22-2009 04:54 PM
cat or cummins cat power The Polling Place 13 02-12-2009 05:21 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Diesel Conversion 0 05-23-2007 05:29 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Whats Been Sold 0 05-23-2007 05:29 AM
