13 speed not shifting right - TheDieselGarage.com
Thread Details Posted by cdwood388, this thread has received 26 replies and been viewed 18629 times.
post #1 of 27 (permalink) Old 03-05-2011, 04:22 AM Thread Starter
I have a 13 speed eaton and the high low on the high side of trans is not working correctly. When its in gear and you shift the red switch to the high side it will work fine, if you shift it back to low it will work fine. If you try to pull it out of gear to upshift and switch the red switch to the low side it will not shift and it just sounds like its trying to shift but its not and it wont go into any gear and you have to stop and start again. What would cause this? I just got the truck and it does this no knowledge if it used to work or what. It shifts great otherwise throught the 9 gears. Any help is appreciated.
cdwood388 is offline
post #2 of 27 (permalink) Old 03-05-2011, 04:41 AM
379Longhood's Avatar
First check to see if your trans has an air filter before the regulator, if so clean it, if not check the air pressure after the regulator, the link to the specs can be found in the handy links sticky at the top of the forum, roadranger literature center, if that is ok the shift fork on the splitter is prolly worn and not putting enough pressure on the syncro (aux section rebuild)
Canadian Club member 27
'88 379 exhd 3406C 15 40s 10 pete unimounts
'93 K3500 6.5 4L80 4" exh
'62 gmc shortbox 454 super t10 big brakes
JD 820 black dash
12V92 waitin' for a truck (mega ratrod)
pettibone s20 3306 pc
379Longhood is offline
post #3 of 27 (permalink) Old 03-05-2011, 11:48 AM
SledMan's Avatar
This is a shot in the dark, but I think you are trying to drive a RTO like a RTLO. You cannot pre-select a splitter shift on a RTO. When you try this, it will get caught in the middle, and like you say, you have to almost stop to get it in gear.
RTLO's are made to change the splitter while you are in neutral with no problems.
I may be way off on this....not sure.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks:1980 KW Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. 2003 Pete EXHD. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3025 squirts. 800 cam. Acert twins via custom mount. ARP head bolts.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline
post #4 of 27 (permalink) Old 03-05-2011, 12:02 PM
359kool's Avatar
Sledman, You could've just said.. Hey now, Quit tryin to split them gears in neutral..
359kool is offline
post #5 of 27 (permalink) Old 03-05-2011, 01:23 PM
OTT
i am with sledman you have to pre select.
2011 389 c-16 stage 2 tune stage 2 injectors stage 3 cam stage 3 turbo Coming soon Twin turbos!
07 379x 625 mxs, stage1 pdi tune,pdi manifold
07 chevy 2500, efi tuned by the master Idaho Rob, 5" exhaust,Tranny built by myself with stage 4 suncoast parts tc1056
PDI dealer in Nebraska
"If I wanted a 7cz tune file I would buy a 7cz"!
The Name Is Dusty AKA Mr.Young Dealer
OTT is offline
post #6 of 27 (permalink) Old 03-05-2011, 01:51 PM
Flyingpig's Avatar
I have always preselected in every 13speed Ive ever driven.
Not to hijack the thread but I have a 14609B that I had a splitter added to. The trans was a rebuild from a respected shop in the area and the splitter was brand new. Ive spent the last 5 years trying to learn how to shift it. All the pressures are correct.
What I found "worked" was to shift to OD then move the lever up to the next gear and downshift to direct. Downshifting worked like it was supposed to. Recently Ive been upshifting by moving the splitter to OD just after the lever has gotten to neutral and hitting the jake to dump the RPMs. It scuffs every gear. If I dont use the jake it wont shift until the engine falls to idle. The splitter works fine if Im not moving the lever.
Who do you call when the lawmakers ignore the law?
Flyingpig is offline
post #7 of 27 (permalink) Old 03-05-2011, 02:06 PM
Thats how a RTO 13 speed is suppose to be shifted.
SL3406 is offline
post #8 of 27 (permalink) Old 03-05-2011, 02:21 PM
Flyingpig's Avatar
I cant agree there. Let me be clear. Lets say Im in 7th direct and shift to OD. To shift up I had to move the lever to 8th OD then shift back down to direct, then as speed increased up shift to OD. That doesnt make any sense at all thats the prescribed way to upshift.
And like I said, for the last 30 years Ive been preselecting all 13 speeds till I got this one built. Granted, mine is a bit a a hybrid. My lowly 9 spd now has 3 overdrives.
post #9 of 27 (permalink) Old 03-05-2011, 03:21 PM
Are you using 1/8" air line on the tranny or 5/32"? I noticed a huge difference after swapping to the larger 5/32” air line. The “dropping out of gear” when trying to split while shifting the lever has almost completely stopped.
Have you also checked the splitter solenoid/plunger on the tranny? If the truck sat for a length of time, or the air system has had a lot of moisture in it, there may be rust buildup in the plunger assembly. A good cleaning will help a lot.
AaronF is offline
post #10 of 27 (permalink) Old 03-05-2011, 04:05 PM
Preselecting puts pressure on the fork and syncro before crossing neutral, which is good if you only flip the button just berfore making the shift, if you leave it for long you wear the fork out, the fork is not hardened to prevent damage to the collar. And if every thing is set up right the syncro will pull it in . Bigger air lines is a good plan. you also need to make sure that the spliter is getting full air pressure in hi range, and is always "live" , it should have full regulator pressure in any gear position while in HI range.
JD 820 black dash
Human Verification
6 speed manual shifting? ehopp88ss 5.9L Cummins (2003-2007.5) 23 03-13-2010 12:07 AM
7 speed spicer to a 9 SPEED EATON/FULLER bayou hotshot Medium and Heavy Duty 6 01-21-2010 10:06 PM
Shifting the 5 Speed Cincinnati Guy 7.3L and 6.9 IDI (Pre 1994) 16 09-20-2009 04:54 PM
shifting a 9 speed meritor kingmike40 Medium and Heavy Duty 9 12-25-2008 12:51 AM
Allison 1000 5-Speed to 6-Speed Conversion stevebos GM Transmissions 8 01-09-2007 06:21 AM
