Has it ever had A/C? If the evaporator is present Behind the glove box in dash/firewall it wouldn't be real difficult. Lines, dryer, trinary switch, condensor, and compressor. i would suggest trying a salvage yard for a donor system. Probably use some sort of aftermarket condensor vs buying an oe grilldensor? And I would strongly urge you to buy conversion brackets or whatever to run a sanden compressor vs york style which was oe. As far as a donor truck, a W900L, T600, T800, etc should interchange with exception of grilldensor. Also you might want to check with an aftermarket A/C vendor like Vintage Air or similar who specializes in complete systems for vintage cars and hot rods.-especially if you are starting from scratch.
Related Threads
The Diesel Garage
1.2M posts
57.2K members
Since 2005
