3406C 8785 nozzles...... - TheDieselGarage.com
Thread Details Posted by SmoothTightKittyCAT, this thread has received 7 replies and been viewed 1739 times.
post #1 of 8 (permalink) Old 06-12-2016, 01:40 AM Thread Starter
I've had the 3zj running for about a month now on the IPD overhaul kit with 16.4 pistons, cat round port reman head with E style exh manifold and CTP 8785 nozzles. My cat turbo says 112-6918, its wastegated and will run 23-24 max boost. My timing is pinned stock.
Pyrometer will hit 900 max. I zip tied the wastegate hose and now the max boost is 28-30 and pyro hits 825-850.
The timing advance and injector pump are both rebuilt as well as a new afc housing. I haven't touched any of these three yet but it smokes pretty good on upshifts and I'm getting just a little more haze than I'd like to have running through the gears (8785s?).
I'd like to advance the timing a half inch on the balancer, and keep the stock turbo pinched for now. Would adding timing with the stock turbo help the haze or should I wait until I have the $$$ for either a 177148 or 174260? It runs good enough right now with no pump/afc mods in my opinion, just the haze and I don't know anyone in N illinois who meter times
SmoothTightKittyCAT is offline
post #2 of 8 (permalink) Old 06-12-2016, 04:05 PM Thread Starter
Pic of upshift smoke and haze
post #3 of 8 (permalink) Old 06-12-2016, 04:07 PM Thread Starter
Smoke on upshift
post #4 of 8 (permalink) Old 06-12-2016, 10:48 PM
SmokinCAT's Avatar
You won't get rid of the haze with a different turbo, those nozzles don't match the 16.4 bowl, depending on how the bowl was designed you may get away with advancing the timing.
Do you recall how thick the washers were under the nozzles you took out?
Cody.
4.11 SQHP rockwells
SmokinCAT is offline
post #5 of 8 (permalink) Old 06-13-2016, 03:36 PM Thread Starter
I will look when I get in, I do remember the 8785s had the same thickness washer as the stockers I took out
post #6 of 8 (permalink) Old 06-13-2016, 11:23 PM
SmokinCAT's Avatar
Cal diesel controls and ask for Jim, give him you old nozzle part number and ask him to let you know how different the angle is on them versus the 8785.
We can talk about timing when you figure out which angles which nozzle has.
Cody.
4.11 SQHP rockwells
The Following User Says Thank You to SmokinCAT For this addition to TDG:
SmoothTightKittyCAT (06-14-2016)
post #7 of 8 (permalink) Old 06-14-2016, 05:21 PM Thread Starter
I talked to jim, according to him the 8785 is 125 degree and the 100-7556 is 136 degree, I'll measure the size of the bowl on my 101-0016 pistons and try to measure them washers tonight
post #8 of 8 (permalink) Old 06-14-2016, 09:41 PM Thread Starter
These piston bowls are 3 3/8 inches across, the washers look like they're 1/16 inch thick.
I also have 100-7557 as my original injectors NOT the 100-7556 like I typed above. I asked the spray pattern for the 7556 so I'll ask about the 7557 tomorrow
Human Verification
3406C nozzles greasemonkey MD and HD - Modification Instructions, Product Installs and Tech Articles 5 01-08-2016 10:59 PM
3406C OR-3587 verses OR-4337 injector nozzles Cat Attack Medium and Heavy Duty 0 05-05-2015 09:14 AM
3406C OR-3587 verses OR-4337 injector nozzles Cat Attack Medium and Heavy Duty 0 05-05-2015 09:12 AM
Cat OR 8785 injectors 2broke2payattn Everything Else 0 12-30-2013 12:42 AM
OR-8785 Heads Up! w9l Medium and Heavy Duty 0 09-30-2013 03:48 PM
