'87 379 build - TheDieselGarage.com
Thread Details Posted by claytoncox, this thread has received 12 replies and been viewed 1239 times.
 5Likes
post #1 of 13 (permalink) Old 10-15-2016, 07:22 PM Thread Starter
'87 379 build
figured i would make a thread for my truck build. i have already came along way with it and have lots of pics to share when i figure out how. its a '87 pete 379 3406b cat with a 15 over trans. pretty sure ive read every thread that tony (ynot) had commented on about these engines and think i have figured oput which way i will go with the motor... when that time comes.
87 379 pete-work in progress
93 d350 cummins - 564/1200 w/ slipping clutch,
04 3500 cummins - compounds,cam,pump,injectors,airdog,yada yada
claytoncox is offline
post #2 of 13 (permalink) Old 10-15-2016, 07:40 PM Thread Starter
heres the day i went to look at it and when i picked it up
Oxbow12 and Cat Attack like this.
post #3 of 13 (permalink) Old 10-15-2016, 08:38 PM Thread Starter
i pulled the 60" sleeper off and replaced it with this 48". this one has hard 90* corners on the rear. i cant seam to find any sleeper skirts for it so i will have to have some made from a buddy of mine.
i shaved the cab lights,horns, and spot lights off filled them, then bondoed (spelling?) them smooth. replaced them with 3/4" lights. also had the dash tore completely apart because wiring was a literal rats nest. head lights and cab lights were theonly working lights on the truck. painted the dash while it was out.
post #4 of 13 (permalink) Old 10-15-2016, 09:04 PM Thread Starter
this is the day i set the sleeper on and got everything bolteddown and hooked back up.
Then came the big project. This one took awhile to make sure everything was perfect. Im on a dirtshop barn so nothing is perfectly level.. That was one factor in the time consuming part. first we cut the frame, caged the braked and rolled the axles back. My father had already stretched his to 325" so luckily we didnt go into this blind.
sanded everything down smooth and primered that section for rust purposes
Ordered a 12ga reverse bowtie visor. 13" on the outside 8" in the middle. took me a while to get it coming from canada simply because i couldnt find this length of one here in the u.s. It will be painted to match the truck.
after searching the worl wide web finally found some "chop top" paintable sides that matched my visor.
this will give you an idea of the shape of this truck when i got it. these are the rear bushings for the axles. new and old.
Luckily for me peterbilt had shoved 3ft of extra wiring and airlines under the cab so that was the deciding factor.
Another friend of mine is a pipeline welder so i entrusted him on the metal melting aspect of it. the frame is doubled now along with bolting cross members across the cuts.
Cat Attack likes this.
post #5 of 13 (permalink) Old 10-15-2016, 09:09 PM Thread Starter
Not sure how that last post got so mixed up, sorry about that.
post #6 of 13 (permalink) Old 10-15-2016, 09:28 PM Thread Starter
Had the hood off so went ahead and started drilling out rivets. ordered a set of "****** custom fenders" for it. the passenger side wasok but the driver side had been patched and riveted from deer sightings so much it was un salvageable.
post #7 of 13 (permalink) Old 10-15-2016, 09:44 PM Thread Starter
Also just realized this is in the wrong section. Could a admin please move to proper place. thanks
post #8 of 13 (permalink) Old 10-17-2016, 01:41 AM Thread Starter
On a sunny day i pulled the truck out to completely primer/paint the frame and suspension.Also set the 5th wheel back on and got it all bolted back down.
Got my set of badazz fenders in after that. they have a 3" lip, 4" longer on the backside with built in mudflap brackets and liners.
here theyare mounted. Also dont have any pictures of it but i built a grille for it out of 1/8" by 1/2" wide aluminum flat bar with 1/2" spacers in between.
post #9 of 13 (permalink) Old 10-17-2016, 01:44 AM
Sounds like you got a good game plan going on. If you don't mind me asking, what do you have in the purchase of the truck? Are you planning on running the engine as is or you going thru it? Thanks for the pics.
Maniac is offline
post #10 of 13 (permalink) Old 10-19-2016, 12:49 AM Thread Starter
i got the truck for 8. it had been sitting up for about 6 months. the motor hasjust over 40,000 on a complete inframe. its one of the smoothest b models ive heard in a long time. i changed all the fluids, did a radiator flush as well since the water filter was taken off. thats still on the todo list
Human Verification
99 379 Pete Ruralcruiser007 Heavy Duty Rebuilds / Rides 6 12-07-2012 01:47 AM
New 379 to the forum's tiffo60 Introductions 5 03-15-2012 01:40 AM
89 Pete 379 88W900 Heavy Duty Rebuilds / Rides 20 01-16-2012 12:59 AM
378 vs. 379 aggar Medium and Heavy Duty 47 10-31-2009 12:13 AM
85 379 mackb61 Medium and Heavy Duty 9 07-11-2007 11:46 PM
