400 big cam III - TheDieselGarage.com
Thread Details Posted by tasbill, this thread has received 3 replies and been viewed 207 times.
post #1 of 4 (permalink) Old 03-05-2017, 10:29 PM Thread Starter
tasbill's Avatar
400 big cam III
I have a 359 with 400 big cam with a eaton 15 speed weighs in around 45000 lbs when you accelerate it has a clatter in the valve train temperature goes up. egt runs right 900 and climbs if I stay in it and this is not full throttle. It does not seem to have power that I think it should have. Any Ideas ? Could this be timing or running to lean only time it blows any smoke is if I lug it. We just did a valve adjustment that didn't change anything. I am use to driving my 3406B.
tasbill is offline
post #2 of 4 (permalink) Old 03-10-2017, 03:15 AM
If you are driving on flat ground in high range at 1300 RPM floor it. At what RPM do you hear this noise you speak of? Put a manual, 300+ psi, gauge in the port on the fuel solenoid. Run a hose and put it somewhere you can watch it while you are driving. What does it say? If you stand in it will it make it to 1150F?
tenwheeler is offline
post #3 of 4 (permalink) Old 03-11-2017, 05:33 PM Thread Starter
tasbill's Avatar
Flat ground high gear pedal on floor: jumps to 150psi then slowly climbs to 175 psi on fuel pressure on port at solenoid valve. EGT went to about 950 degrees F . The valve rattling starts as soon as you mash on pedal . Also when pressure gauge was hooked up the engine was slow to come back to idle after releasing pedal.
tasbill is offline
post #4 of 4 (permalink) Old 03-14-2017, 02:11 AM
That sounds pretty normal to me. Those engines normally had a noise-rattle when under load. Kind of like a car with a gas or preignition rattle. Accelerating from low RPM it would usually start about 1550 RPM and go away at a free running higher RPM and or when accelerator was backed off. A lot of variations of those were made over the years that had a little different operating range.
For low power problems search NTC low power trouble shooting. Cummins low power type questions. Does the throttle brake over, filters, fuel lines, exhaust etc.? Maybe just not up to what you were used to but nothing wrong with it? They are easy to get a little more from but be sure it does not have some other problem first.
Human Verification
big cam III questions again truckdriver_mn Medium and Heavy Duty 25 01-05-2011 06:12 PM
Big cam III truckdriver_mn Medium and Heavy Duty 1 10-25-2010 12:34 AM
Big Cam III - PT320 to Formula 400 6V-92TTA Medium and Heavy Duty 70 07-20-2010 03:26 AM
Big Cam III in pulling truck seven Medium and Heavy Duty 10 08-21-2009 02:59 AM
Cummins Big Cam III Manuals? kblackav8or Medium and Heavy Duty 1 06-01-2007 12:18 AM
