95 Ford 8.3l 250hp pump shaft fuel leak. - TheDieselGarage.com
Thread Details Posted by w9l, this thread has received 3 replies and been viewed 88 times.
post #1 of 4 (permalink) Old 04-21-2017, 08:55 AM Thread Starter
w9l
w9l's Avatar
Anybody had any experience with re bushing and sealing throttle shaft on a Bosch inline on a 8.3 Cummins? Easy? Special tools? Do it without pulling pump off engine? Any links to step by step? Just trying to help out a neighbor with his lime/ fertilizer Ford F800. 95 model I think. Leaking a pretty fair amount of fuel.
Just me
w9l is offline
post #2 of 4 (permalink) Old 04-23-2017, 12:57 AM
I thank that is a job for the fuel pump shop.
tenwheeler is offline
post #3 of 4 (permalink) Old 04-23-2017, 04:20 PM Thread Starter
w9l
w9l's Avatar
Might well be. Owner was quoted 3400.00. Pump shop said they would have to go through the whole thing. Runs fine. Just leaks. I figured it probably wasn't any more complicated than a 3406b or c- which I have been into more than one and managed to fumble through it and get back together. Thanks in part to people I have become acquainted with on this site.
Just me
w9l is offline
post #4 of 4 (permalink) Old 04-24-2017, 05:49 PM
If it's a Bosch P series pump it should leak oil if the throttle shaft seal fails.
If it's leaking fuel There is a leak somewhere else.
Terry
terry_g is offline
Human Verification
Cost of changing ford 6.0L fuel pump davidclayton 2008-2010 6.4L Power Stroke 0 12-09-2015 12:36 PM
fuel leak on VE pump gon2sea 5.9L Cummins (Pre 1994) 1 04-20-2014 09:48 PM
DT466 fuel leak from injection pump zag Medium and Heavy Duty 6 05-10-2011 12:59 PM
need help locating fuel pump on ford 7.8l aja458 Medium and Heavy Duty 4 10-20-2009 07:14 PM
fuel pump leak 1991cummins 5.9L Cummins (Pre 1994) 9 04-29-2007 11:28 PM
