1998 4700 Brake pressure light ? - TheDieselGarage.com
Thread Details Posted by imported_curbguy, this thread has received 8 replies and been viewed 12471 times.
post #1 of 9 (permalink) Old 01-22-2007, 03:39 AM Thread Starter
Hello, I just purchased a 98 4700 with 466e motor and a 6+1 trans. It has juice brakes and the brake pressure light comes on after 20 min. of operation. If I turn the truck off and on again. It goes out then comes on shortly thereafter. I don't notice any difference in brakes, they seem good. Truck has 111k on it and I just don't know enough yet to know where to start looking. Any help would be appreciated. Thanks in advance. John
imported_curbguy is offline
post #2 of 9 (permalink) Old 01-23-2007, 02:44 AM
You need to start checking pressures. We had a few trucks w/intermittent brake prssure lites. We never fixed them and never lost brakes but dont like having drivers tell ou that tthe light comes on. Boss says as long as you still got brakes dont worry about it . It only takes one time they dont work to make a heck of a mess.
#23 Singles Club
thejdman04 is offline
post #3 of 9 (permalink) Old 01-24-2007, 02:10 AM
Working 24/7
I had the same problem with my truck. If you go here. http://www.bscparts.com/pdfs/hydromax.pdf and you'll see in the first pic [integral flow switch]. I just had to replace the switch and it stopped. I cant guarantee it but it worked for me. Its a very cheap part at the I.H. store and they should have it in stock. I have also seen the ignition switches cause problems to. They get hot at the back of the switch and it melts the big connector that plugs into the back. Just remove the switch and inspect the back of it.
Tow man is offline
post #4 of 9 (permalink) Old 01-24-2007, 04:55 AM Thread Starter
Thanks for the tips!
Thanks, I will try this tomorrow and see if we can fix it. I noticed that the fluid is about 1" below the cap ring. Isn't it supposed to be up to the ring? I will try fluid first and then check the other items you mentioned. Thanks again. This forum is a great resource. John
post #5 of 9 (permalink) Old 01-24-2007, 01:56 PM
Fire App. Mech.
The fluid will always drop as the pads wear but as long as there is a good amount in there it will perform the same. You should never have to add any during normal use, that indicates a leak. I flush them out with new fluid from time to time and always fill to the top after a brake job (I buy loaded calipers so I lose the fluid that is in the old ones).
Birken
Birken Vogt is offline
post #6 of 9 (permalink) Old 02-08-2007, 02:42 PM Thread Starter
98 4700 brake pressure light
Well we changed the sensor, all the fluid is up and went to back out of the shop and the light and buzzer came on. Shut truck off for 5 min. started and no buzzer or light. Drove 15 miles and no buzzer or light. Went to back up and you guessed it, buzzer and light on. It seems to only be coming on when I back up. Does anyone know if it could be due to the fact that it is a cab/chassis that only has the brake lights and turn signals hooked up, that could cause it to trip somehow? I can't think of any other reason for it to happen. It only comes on in reverse. :shrug:
post #7 of 9 (permalink) Old 02-08-2007, 05:10 PM
a good cause for that light to come on for no apparent reason can be from brake switch issues the brake switch is a 2 part switch it recieves power from two sources and sends power out from each side of it .
check to see if both sides of the switch have 12 volts to them with no brake applied then check that both outputs get 12 v with brake applied if that checks out ok then another possiblity is back feed of power thru tail light or even reverse light circuits verify the tail lights have a good solid ground to them and that the lights are properly wired in
Photos of The Beast
DOC
Docluv2577 is offline
post #8 of 9 (permalink) Old 02-10-2007, 01:16 AM
Super Moderator
John_G's Avatar
Bad grounds in the brake/tail/back-up lights WILL cause the Brake Warning light and buzzer to activate for no apparent reason.
Reason: The brake circuit does not have a blocking diode in it to prevent "backfeeding" of electricity due to an open or partial ground circuit in the rear lighting circuits.
Cause: Loss of good ground allows electricity to "back feed" from another circuit sharing the same ground as the BRAKE lights, into the Brake Warning Module. The module detects ONE brake signal, but not two, and illuminates the warning light and sounds the alarm. The module is designed to do this as there are two seperate brake switches, and it thinks one has failed.
This is VERY common.
I vote for LIBERTY!
John_G is offline
post #9 of 9 (permalink) Old 02-11-2007, 07:29 PM Thread Starter
Thanks to all that gave feedback, I did get my flatbed installed and wired and you were right. The warning light and buzzer do not come on at all. Simple fix, and a little more knowledge gained. Thanks again. John :thanks:
Human Verification
