set-forward vs. set-back axles - TheDieselGarage.com
Thread Details Posted by dondiesel444, this thread has received 10 replies and been viewed 7507 times.
post #1 of 11 (permalink) Old 10-07-2005, 10:33 PM Thread Starter
dondiesel444's Avatar
I always liked the look of set forward alxe trucks. what are the advantages of set back vs. set forward???
dondiesel444 is offline
post #2 of 11 (permalink) Old 10-07-2005, 10:40 PM
fordt
Do you mean like on a Peterbilt front axle?
If so, it's all about manuverability.
post #3 of 11 (permalink) Old 10-07-2005, 11:00 PM
Down With The Slickness
Send a message via AIM to Deezle1
the set back will give you a better steering diameter, but lessen the ability to load the rear more. the set forward will allow you to stack more weight on the rear axles because there is more balast (sp) out front...least thats my way of thinkin.
JR
a figment of you're imagination...
1997 dodge ram 1500 4x4 318 auto: summit ignition, fastman throttle body, holley fuel pump 23lb injectors, 180* high flow t stat, open element intake, 3 inch cat back exhaust out the side, high flow water pump, high pressure oil pump...needs trans.
87 Chevy K30 6.2 4x4 4 speed...restoration/build
Deezle1 is offline
post #4 of 11 (permalink) Old 10-08-2005, 02:33 AM
axles
At work we prefer the set back axle, more manuverable with 57' trailers. We can get our KW T-600's in were we can't get a Pete 379 or KW 900.Rick
01' F-350 4x4,CC, LB, SRW, BTS, BB Turbo, 4"straight, Stealth oil, DP tuning, ITP fuel, Autometers on pillar.
stroker is offline
post #5 of 11 (permalink) Old 10-08-2005, 02:44 AM Thread Starter
ok I see now, set backs allow the tires to turn more. it's weird but I think my Mack R model has a pretty tight turning radius, a LOT tighter than my old Int'l 4900, both are set forward axles. I guess every truck is different. I know my Dad's 94 Autocar dump (was a tractor) has a terrible turing radius.
still I personally don't like the looks of most set back axle trucks, with their long noses, better for aerodynamics though. I like big square hoods!!
post #6 of 11 (permalink) Old 10-08-2005, 04:25 AM
Fire App. Mech.
Yeah who needs manuverability when you look good!: 90% of the dirt haulers around here are running 379s or 900s. They get into some pretty tight places with them too. I guess if they had set back axles they could go tighter but they don't and the fact that they have 379s shows that they must be making a few bucks at it anyway
Birken
Birken Vogt is offline
post #7 of 11 (permalink) Old 10-11-2005, 04:31 PM
Loves Jet Noise
NoWake200's Avatar
Send a message via Yahoo to NoWake200
Does anyone have any good pictures of the two set-ups they could post?
The 379 day cab I once drove could turn on the dime, almost as good as the Volvo. :Thumbup:
TWA
2011 F-350 Lariat, 6.7 PowerStroke, Crew Cab, Short Bed, White with 20" Wheels.
NoWake200 is offline
post #8 of 11 (permalink) Old 10-12-2005, 12:50 AM
RCFFD #47
Send a message via AIM to DBogo
both 378's
personally i like the set backs better
1995 Ram 2500 12v NV4500 4x4, 5" ss straight piped , ICEBOX, #10 place, 215 injectors, 4.5gsk, afc full forward, cranked starwheel, autometer boost/pyro, jacobs exhaust brake, 60lb springs, boost elbow, KDP tabbed, HID's, DT Profab +1/2" control arms, silencer ring MIA, air horns
1988 Mack RD690, 300, 8spd, 17' Bibeau dump, electric tarp, leds all around, 2 stage jake, 6" straight stack, the 'ol dog barks
1983 VW Rabbit Pickup, 1.6 N/A, 5spd, stock for now
The Desire to Serve, The Ability to Perform, The Courage to Act 100% Volunteer
DBogo is offline
post #9 of 11 (permalink) Old 10-18-2005, 08:45 PM
Loves Jet Noise
NoWake200's Avatar
Thanks for the pics, the bottom one is a 379 I thought. That is the one I used to drive when I was hauling heavy equipment. Believe it or not, that truck had a good turning radius.
TWA
post #10 of 11 (permalink) Old 10-18-2005, 08:57 PM
VIRUS FREE!
Nope,both are 378's.One SFA,oneSBA
Jim ..... I Don't Do Window's!!!
'06 F-350 CC DRW LB King Ranch 4x4 PSD TOW BOSS
'05 TJ Willys Edition 4x4 4.0
'59 Caliente Vieja
FLRin29 is offline
Human Verification
Anybody else from Maine? JIMS 03 73 Northeast 13 12-03-2009 06:24 PM
The Singles Club my97stroker The Parking Lot 358 01-16-2009 08:47 PM
test cumminsdieselfreak Testing 1 12-30-2008 02:38 AM
Chat session tonight Unbroken The Parking Lot 12 10-02-2005 08:08 PM
